584,866 active members*
4,940 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Merging layers in SolidEdge2D Drafting
    Sep 2005
    287
    Can layers be merged / flattened in SolidEdge 2D or can you only transfer elements from one layer to another, then delete the empty layers.
    Cheers,
    Keith.
    In AutoCAD you can select the items you want on a different layer, and then change the layer they are on with the layer dropdown, or you can open a properties window and change the layer they're on.
    I'm assuming they'd have similar functionality?
    Sep 2005
    287
    Thanks Ger21,
    yep thats how I did it. Having used Photoshop a little bit I was wondering if engineering cad programs had similar functionality but I guess it's different for image editing applications than it is for cad.
    Keith.
    Apr 2010
    294
    Yes you can transfer elements, but you can move all the items in one go: select all the layers (click on the first one, hold shift, then click on the last) then click the "select all" button to highlight all the drawing elements, then Move Elements and select your target layer. You can delete all the unwanted layers together, too.
  1. The key to merging
    By cncadmin in forum EnRoute
    Last Post: 03-15-2012, 06:40 AM
  2. Program Merging
    By KaesynCAM_Tech in forum Okuma
    Last Post: 09-12-2009, 07:06 AM
  3. Text tranfee from solidedge2d to Mach3
    By zirakon in forum Uncategorised CAM Discussion
    Last Post: 04-08-2008, 08:34 AM
  4. a little help with merging
    By Craigpat in forum Solidworks
    Last Post: 03-17-2008, 12:49 PM
  5. Drafting
    By jorgehrr in forum Autodesk
    Last Post: 10-10-2007, 09:50 PM
