As you can see by the label it is 208/230/460 parallel or series for the different voltages.
It cannot be ran on 120 successfully, there is a way to use one 0-208 primary and use the other winding H5 & H6 in buck mode to create a 196v primary but it is going to be in a crippled fashion, VA wise.
Otherwise use the 208 connection shown and you will get half voltage secondary output at derated VA.
Al.
Albert E.
