Anyone know how to find and "PING" a multicam IP address from the networked computer?
What is the problem that you are having with your connection?
on your keypad hit shift, then the help key (?), then 2 (v). this should display your cnc controller's network information including the ip address. If you hit the DNC key while the network information is showing you can set a static ip.
