585,977 active members*
4,113 visitors online*
    Mar 2009
    20
    5 Axis Foam Cutting program
    Hello! Do you some 5 Axis Foam Cutting program with option for rotative table? I want to make this kind of CNC but I can't find any suitable program. Thank you!
    [ame=http://www.youtube.com/watch?v=edkp1OxUGnY&feature=player_embedded]ThermoCut_car - YouTube[/ame]
    Dec 2011
    Re: 5 Axis Foam Cutting program
    You dont need a 5 axis. Only a 2 axix X&Y and a 3rd axis to rotate material. View youtube. Search for "comcli" user and watch the movies.
    Apr 2004
    5737
    DeskProto writes continuous 4th axis toolpaths and 5th axis indexing is possible. Foam's not a problem. See DeskProto: 3D CNC machining for non-machinists. STL file milling for any CNC milling machine
    Andrew Werby
    Website
  1. 2 axis foam cutting.
    By venomx999 in forum CNC Wire Foam Cutter Machines
    Last Post: 12-01-2012, 08:23 AM
  2. BobCad wire EDM for 4 axis CNC foam cutting
    By Jerry3672 in forum BobCad-Cam
    Last Post: 11-16-2012, 05:06 PM
  3. Software for 4 axis foam cutting
    By Andy Smith in forum Controller & Computer Solutions
    Last Post: 12-26-2009, 11:00 AM
  4. Foam Cutting Rotating Axis
    By professionalcnc in forum Italian
    Last Post: 10-30-2008, 07:38 PM
  5. Need help with 4 axis foam cutting.
    By bakersman in forum CNC Wire Foam Cutter Machines
    Last Post: 02-17-2007, 02:43 PM
