585,962 active members*
4,097 visitors online*
    Sep 2012
    Hypertherm 600 consumables
    Hey All,
    I recentally got in possesion of a plasmacam table with a hypertherm 600 torch. Currentally it is running a drag shield and is less than optimal. Currentally it creates a curf that is too wide, and create a bit more dross that I'd like. The height is set properly and speeds are the settings that hypertherm recommends in the manual, i have modified them back and forth a bit as well. I believe that switching over the shield to a machine shield, as well as fine cut consumables would potentially help the curf issue, and potentially the dross as well. Im looking here:
    FineCut Parts & Kits
    specifically the 220326 and the 220330
    should i also change the swirl ring?
    How is consumable life, i assume less, but by what margin.
    Additional details:
    The table runs DHC, and I typically cut 16Ga 11Ga and 1/4", will I have problems with the 1/4" with the fine cut consumables?
    Sep 2012
    in retrospect, it appears as though fine cut would work well for my sheet metal, however maybe not so much on the 1/4" material, is there a better combo of consumables that i can use for the 1/4" thicker material?
  1. Hypertherm Consumables / Jim Colt
    By magma-joe in forum DynaTorch
    Last Post: 09-21-2015, 09:57 AM
  2. Hypertherm Finecut Consumables
    By none in forum Hypertherm Plasma
    Last Post: 04-02-2012, 03:46 PM
  3. Used Hypertherm consumables needed.
    By AccuFast2D in forum Waterjet General Topics
    Last Post: 10-01-2009, 01:47 AM
  4. hypertherm consumables
    By Pure-Powder in forum Waterjet General Topics
    Last Post: 06-04-2008, 04:26 AM
