I need everyone's help again with a Fanuc 6M control on an old Acroloc machining center. I'm sure it's a couple parameters I need fixed.
When the machine is running a program the control does not pick up the programmed feedrate nor does the feedrate override switch work at all.
I discovered the only control of the feedrate I have is using the manual jog
feedrate switch and remember thats when in program mode and the machine is running a program.
Also:
Again while running a program I have to press and hold the rapid button for the axis' to move at rapid rate.
I hope someone can help me out and I appreciate any words of help.
Thank You!
TC
