Along with other posters in this forum, we, too, are having issues with our Fadal with 104/D.
However, we are relatively new to machining, and have only been running the machine about 8 hrs, 4-5 days per week, for the last 4 months.
Not having ever owned a CNC mill before, I am not sure what kind of issues are considered "normal", and what should be deemed excessive and unacceptable.
We did find that a lot of our issues, such random control freeze-ups or Internal Errors, went away when we went to a dedicated off line CAM suite and stopped switching to the preloaded Gibbs software.
However, there have been issues since then in the last 3 months:
1. Dropped tool
2. Machine would randomly stop during machining, resulting in a broken end mill - Complete Control replaced.
3. 3 dropped tools. - Software updated
4. Software glitch, won't change tools. Extra tool change call inserted in programs.
5. Machine stops again during machining. Software updated (tool change glitch fixed)
6. Startup error - "CAN init failed"
7. 4 dropped tools (tool broken)
8. 1 dropped tool - ATC adjusted
9. 1 dropped tool - first tool change after adjustment (and after technician has left!)
As of now, we have lost a couple end mills, but some of our flycutters have also been dropped, which could have a much more expensive consequence for us if that continues.
The dropped tools have also resulted in nicked and ultimately scrapped parts, as well as some marking of the table.
Given our lack of history using CNC machines, I am not sure if "some" issues like this are to be expected with a machine like this, or if *any* of these problems should considered unacceptable.
Remember, we are not a job shop, and these issues have occurred with fairly limited use compared to a multishift job shop.
I am under the impression that the machine is built to a different spec when equipped with a 104/D control, so swapping in a Fanuc or other make control is not possible.
If that means a complete machine change out, I am not sure if we should just "suck it up" or bite the bullet and go for extreme measures like a change out.
I am also concerned about being stuck with "abnormal" issues after our warranty runs out.
So basically, for you experienced machine and business owners out there:
What would you do?
Thanks in advance for helping the noobie!
Dave
