585,604 active members*
3,247 visitors online*
    Jan 2007
    14
    Mazak M-2 comunication setup???
    Hi, everyone!
    I´ve been here on cnczone but this is my first post.
    I´m having trouble connecting Mazak mazatech h-400 with Mazatrol CAM M-2 to PC, and everything I have tryed just doesen´t work.
    Cable I´m using is null modem. Connected like this: (x-y, x-> PC DB9, x-> mazak DB25) 2-3, 3-2, 5-7, PC has jumpered 1-4-6 and 7-8, cnc has jumpered 2-6-8 and 4-5.
    Cable was tested on fanuc, and was working.
    I think that I´ve actualy tryed every posible combination of rs232 settings both on pc and machine.
    If I use punch or tape, I can´t receive nor send any data. But if I activate DNC function, I get scrambled data to mazatrol, and if I power mazak off and back on, it restarts with alarm.
    Can anyone give me some guidelines how to upload ISO files????
    P.S.
    Mazak has the FX17 board...
    Apr 2005
    175
    RS232
    You might try looking at this link from Cadem.com and see if your settings and cable are correct.
    Cadem CNC programming, CADCAM, Education, Training, Cycle time reduction, Conversational CAD/CAM, MES, OEE, Lean, TPM, DNC, Free DNC
    Jan 2007
    14
    On my machine, "I" parameters are defined as cutting parameters.
    By my operating manual, parameter OP16 is for RS232 specification, OP23 is for tape baudrate and OP24 is for punch baurdate.
    Parameter Y04, bit 0 is to enable/disable DNC. Currently it is disabled...
  1. how to setup tool life on Mazak Nexus
    By kenickie22 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-09-2011, 11:30 PM
  2. MAZAK MR-J2 Setup Software Manual
    By mapleleaf in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-05-2011, 03:15 AM
  3. CNC Program/Setup/Operat Mazak Mill with Mazatrol - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 10:25 PM
  4. MAZAK MULTIPLEX PROGRAMMER AND SETUP MAN
    By Denis13 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-15-2008, 07:19 PM
  5. Chuck Jaw Setup Mazak Fusion 640 T need help
    By Shotout in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-28-2006, 02:17 AM
