I am using the generic router post processor. When my g code generates there is no "s" value for speed so the spindle will turn on when I first start the program but when it gets to the first tool change it goes to home and without hitting cycle start again the program will carry on and not re-start the spindle. I can go in and manually write the lines, but is there a way the bobcad can generate the correct code? BTW I am using a mini maxpath with a modified mach 3 controler that came with the machine.
