585,914 active members*
3,751 visitors online*
Results 1 to 7 of 7
    Oct 2004
    29
    Lightbulb Head to Table angel
    Hi everyone that reads this,
    Any input is much appreciated. Here is what I have: I have a Grizzly G8689 mini mill. The head is at a slight angle to the table resulting in deeper cuts by the outside edge of the tool than the inside edge. This makes the work look bad and gives other non-desired affects in the work (Angels on drills, etc.) I have attempted to correct this by using aluminum sheets(wedge). I think I have 7 sheets now and I am still not where I think I should be.:violin:
    How do others go about fixing the squareness of the head to the table? :idea:
    CES
    Rudydubya shows you how.
    Mini-Mill Spindle-Column Alignment - Home Model Engine Machinist
    Tramming is a must.
    Shop Info
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Oct 2004
    29
    Thanks!!
    Ah the answer and just a few more tweaks and, oh this is the information I was looking for.
    I have heard of the bar method before but did not understand it due to mainly no pics.
    Very cool. There might be a need for a way to control the movement but this will get me trammed in the mean time.:cheers:
    Nov 2009
    4415
    I thought this thread had something to do with an angel loooking over you while machining! I needed one. :-) JK
    Oct 2004
    29
    Re: Head to Table angel
    Due to a stroke, my left hand is faster then my right.
    May 2013
    149
    I reckon hoss has a 3 bolt mod that will fix it, the one bolt method for those mills is a woeful design.
    Wisdom results from foolishness!
    Oct 2004
    29
    Zenji, Can you supply a link?
  1. ... And Behold an Angel did appear to clear my driveway
    By Al_The_Man in forum Community Club House
    Last Post: 12-22-2010, 08:47 PM
  2. Head/Table Alignment
    By Tazzer in forum Haas Mills
    Last Post: 11-16-2009, 06:00 AM
  3. Any one have an Angel to share?
    By teamtexas in forum DIY CNC Router Table Machines
    Last Post: 04-08-2008, 03:54 AM
  4. My Angel 2000 CNC
    By corydoras in forum CNC Wood Router Project Log
    Last Post: 12-11-2006, 09:58 PM
  5. Bob Shores Little Angel
    By cncfreak in forum I.C. Engines
    Last Post: 02-29-2004, 01:27 AM
