585,744 active members*
4,021 visitors online*
    Apr 2008
    123
    g-code for sinumerik 828d problem
    HI all,
    I am trying to get my Edgecam to post g-code correctly to my new 828d shopmill control.
    I'm unsure as to how the code SHOULD look.
    I have tried older g-code programs but it seems to be mainly the tool call and a few other codes that are fetting in my way.
    I have used codewizard before to sort out my Hurco postprocessor but this siemens is giving me a headache.
    Does anyone have a sample code OR can anyone guide me into how to changing what I need to change in order to get this to work for me?
    Jun 2008
    20
    I used to work with Sinumeric 820D control on Deckel Maho machine. I used Mastercam for programming - the G code worked in ISO mode only not in Shopmill. Shopmill has built-in conversational programming and I am not sure if the ISO G code works in Shopmill as well.
    Sorry, I can't help you with G code for Shopmill, but if you try ISO mode I am sure you will get the results.
    Regards,
    ZedB
    Apr 2008
    123
    Well after spending 3hours with a good sample of the siemens g-code and Edgcam's code wizard I have a first workable post..
    I am currently running a few test programs (in acetal)
    So far so good.
    I was advised to use the Fanuc template from edgecam and modify that..
    It appears to be working but a few more days of testing is needed to be sure.
    Thanks ZedB for your reply. :-)
  1. Siemens 828d continuous path mode problem
    By Michaelt83 in forum Mastercam
    Last Post: 01-05-2015, 08:56 AM
  2. NC Code edit software for 2 channel Sinumerik 840D lathe
    By Sergio_plc in forum SIEMENS -> GENERAL
    Last Post: 11-23-2012, 11:51 PM
  3. Problem with Siemens Sinumerik 3M
    By nyhoyn in forum SIEMENS -> GENERAL
    Last Post: 12-15-2010, 04:19 PM
  4. An example G-code for Sinumerik
    By sion in forum G-Code Programing
    Last Post: 09-13-2010, 02:35 PM
  5. G-code example for sinumerik
    By ari vederchi in forum G-Code Programing
    Last Post: 11-09-2006, 06:03 AM
