Are you trying to go from scan straight to cutting product? If so, a route would be something that give you stl output (or use a home built scanner and convert with Acutrans) then use Stlwork to generate g code. If not, you could make a probe, use Mach2, create a point cloud, use polyform to make it CAD useable, then from CAD back to Mach2 and cut. Sorry I'm not near my shop/garage and machinery to ops check this approach - but I've had a bit of time to think about it. <Note:I'm not associated with MACH2 or IMserv - but both have good products!>
:cheers: Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
