585,719 active members*
4,544 visitors online*
    Jun 2012
    393
    Smile My first problem
    I am new to all of this. I am also a button pusher ?? I must have made a change that now effects what I am trying to do. I tried all of the reset option to default and it does not help. I am getting an error about the size. I am loading the shied model from the DeskProto site. It is coming in at x 130.9603 + .2362 = 131 inches Y also and z at about 70 inches. The error message says this is bigger then my machine. PS : it is also bigger then my house. LoL do I need to reinstall DeskPtoto or can I fix this.
    Thank You
    Apr 2004
    5734
    It sounds like
    The model is in millimeters, but you're working in inches (and living in a very small house). Either switch to millimeters or re-size the model. To re-size the model, go into Part Parameters (right-click) Transform. In the Scale box where it says 1.00000, put 0.0394 to convert it into inches. If you want to work in millimeters, go to Options/Preferences and switch the Measurement Unit to mm instead of inches.
    Andrew Werby
    www.computersculpture.com
    Authorized DeskProto Reseller
    Jun 2012
    393
    Thanks for the reply. I will need to keep this number handy. I will always be working in inches.
    Thank You
    Apr 2004
    5734
    The other magic number is 25.4 - that's for when you're going the other way, and need to turn inches into millimeters.
    Andrew Werby
    Jun 2012
    393
    Thank you for the numbers. I am saving these as hints. This will be a big help.
    I will be making another post soon and it will be a question .
    Don
  1. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  2. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
  3. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
