Looking for a parameter list for a 220 with T1 control.
Would also buy/rent/borrow an MSD tape. Let me know what you have.
Thanks.
Thanks.
zahnrad_kopf,
No need to rent or borrow a MSD tape. All you need to do is to locate some one that has a T01 control and would be willing to make a hard copy of their machine parameters. Tapes are EXTREMELY hard to find and the tape deck is EXTREMELY prone to fail. Enter the parameters manually and set up for serial file transfer.
I would be more than willing to supply you with the parameters, but I have a T02 control and the parameters will not work with a T01 control.
Good Luck,
Ron
Thanks, the issue seems to be actually finding an actually known good parameter list for a T1 lathe...
Is this Mits T1 control? I have the parameters for a T1 Mits/Mazak, and also the parameter descriptions might help?
Also how to clear memory and renter.
There are not that many on a T1 to enter by hand.
Al.
Albert E.
zahnrad_kopf,
When you stated that you needed parameters for a 220 with a T1 control then I assummed that you had an EMCO 220 with an EMCO T01 control. Is that correct?
Ron
Ron, yes, you are correct. I have a 220 with a T1 control.
And yes, a hard (digital) copy of the parameters so that I can enter them would be great.
I've actually been muddling around in there by now, and have it going
*SOMEWHAT* but am working with bits and pieces of information so am kind of winging it...
Solved. Got my call back from Emco. Retrieved from Austria and sent to me.
