we are looking for distributor for universal printer.
• This kind of printers use germany Technical grade Muto print head, the advantage compared with other print head is : fast speed, high resolution, durable and low cost of maintenance. especially for large batch production, it is stable and low failure rate, it works well in all kinds of environment, which is better than many other smaller printers in the market. The speed is 8 to 10 square meters per hour, which is the double speed of Epson machine! The Muto is the best choice of high speed, mass quantity and high effective production. This printer , the max print height is 20cm and the size is 250cm*114cm, which is widely used with leather belt, glass door, metal plate, ceramic, garment and some other fields.
