Ok back to the original problem. If you look at the back view I have 2 red splines coming down to 2 pink splines. Only they don't meet. When you zoom in real tight you see the red splines are "A" twisted and "B" they don't meet up with with the surface I changed to pink.
So how does one do a repair and reconnect the dots so to speak.
While I watched Video 66 Import repair surfaces.
I don't have matching edges around plates to repair like in the video.
I'm hoping for some help before Monday when I can get SOD on board.
The end goal is to combine front and back views into on 3D solid to machine in renshape in 1-50th scale with 3D tool path. I'm running V25 pro.
Thanks all.
