Yes, I know how to modify a post, in fact I have modified this one twice already, but a lathe is different. On my mill all that is needed is to retract the tool and then move the table. Works 99.9% of the time unless you are using special fixtures etc.
But, on a lathe you have OD and ID. The rapid move out of a bore is very different from an OD turning operation. On an OD you move X then Z. On a bore you move Z then X. In each operation in the cam tree on the lathe, you have a rapids option just for that reason.
Here it does not even retract the tool out of the material, the tool is still engaged when the spindle is stopped and the program ends. You can't write a post that will understand and do the right moves at that point. It has to be Bob-CAD that does that. It should retract the tool and return to a preset or standard place like the tool change position.
Thanks, but it is not a post modification.
Mike
