Hi everyone.
I want to build a rotary positioner for my welding robot. I have a low budget and i have little knowledge on the subject.
I need a minimum torque of 1600oz/in on the positionner. Bigger torque would be welcome.
I was thinking using a timing belt and gear kit similart to this one here
I can't use direct drive as i don't have enough place behind the positionner to set up a motor.
I was looking at a nema 34 step motor kit may be this one here
What i want to do is to be able to rotate 45-90-135-180-225-270-315-360 degree rotation. It don't have to be fast.
And i might need to do continuous rotation at different speed.
i have digital output on my robot from which i can send pulse from 0.1 sec to as much as i want. I don't want it to be pulgged on a computer to be running. I'm looking for a solution i can program and execute "routine" depending on either the i/o activated or the amount of time an i/o is activated.
would you use a timing belt like the one in the ebay link of another solution?
I'm i better to go with a integrated Step Motor + Driver + Encoder + Controller?
Thanks you for your help
David
