585,981 active members*
4,307 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Milling plaster help
    Sep 2012
    Question Milling plaster help
    hello, I am new to the forum.
    and obviously I need some help.
    I am milling a plaster mold.
    I need help with Rhino cam settings?
    I understand that plaster will let out a lot of dust and could damage the machine. But I saw this video and he don't have any dust.
    [ame=http://www.youtube.com/watch?v=PT-NyezsqoQ&feature=relmfu]Milling Plaster - Part 3 - YouTube[/ame]
    any information on the feeds& speeds and step over will be very helpful, and also machine Safety.
    looking forward to hear your comments!
    Thanks!
    Apr 2004
    5737
    It's hard to say from a video, but in that one he's just doing the finish pass with a very fine-tipped tool, so there isn't much dust being generated, and what there is is being blown away by the downdraft from the spindle. You can see it accumulating on the table at the top of the screen.
    Plaster of Paris (calcium sulphate) isn't an abrasive material, so its dust won't damage your machine more than wood dust, but you can minimize it by adding a little white glue to the water before mixing it. Let the blanks dry thoroughly before carving them, since it (and any cutting debris) will be sticky otherwise.
    It's impossible to tell you what speeds and feeds to use without knowing what you're carving, how fast your spindle goes, what tool you're using, etc.
    Andrew Werby
    www.computersculpture.com
    Nov 2009
    30
    Try using Vacuum cleaner
  1. Anybody ever milled hard plaster?
    By KevinWilkins in forum Haas Mills
    Last Post: 08-31-2008, 09:15 AM
  2. Making Plaster mold for casting A356
    By navnav2006 in forum Casting Metals
    Last Post: 08-17-2008, 01:25 PM
  3. Plaster Patterns
    By mtuckf in forum Moldmaking
    Last Post: 05-20-2004, 11:56 PM
