585,733 active members*
4,878 visitors online*
Results 1 to 7 of 7
    Jul 2012
    13
    G-code and floating point numbers?
    I am working on an excel software tool for adding corners to tool paths for our drag knife tool. This program is functioning with shopbot code already. I am just sort of learning g-code in making the translation.
    I have created a macro that will import g-code G00 and G01 commands. I have been using a sample code someone sent me as a test piece for import. It appears to contain floating point numbers. See these lines:
    N210G1Z0.0000F60.0
    N220G1X2.5831F180.0
    I'm assuming that 0.0000F60.0 represents 0.0000 X 10^-60
    Please let me know if I am wrong on this.
    Unfortunately excel would represent that number as 0.0000E-60 and I don't see an easy way of interpreting this floating point format with excel. Does anyone have experience with this? Can you make any suggestions?
    N210G1Z0.0000F60.0
    Means move to Z 0.0000 at a feedrate of 60 inches per minute.
    Jul 2012
    13
    N210G1Z0.0000F60.0
    Thanks.
    May 2004
    4519
    N210G1Z0.0000F60.0
    +1
    G-code works on Word Address format. Each letter and the following number makes one Word. Think of the letters as variables, sort of like in algebra. Then you can assign numerical values to those variables.
    N=210
    G=1
    Z=0.0000
    F=60.0
    Jul 2012
    13
    Quote Originally Posted by txcncman View Post
    +1
    N=210
    G=1
    Z=0.0000
    F=60.0
    Thanks. Understood. I did not realize feed speed was changed within a move command. G-code is quite different from shopbot's code and it can be confusing to look at a long line of code formatted completely differently from what you are use to.
    Quote Originally Posted by donek View Post
    It can also be changed on it's own line. It's also modal, so once changed, it remains in effect until another F word is used.
    Apr 2010
    294
    You must understand that excel can display a number differently form the underlying absolute value. You can round the underlying value to a specified number of decimal places by encasing your formulas in a ROUND function. So =ROUND(restofformula,3) will ensure that you only get three decimal places and no silly results like 0.0000E-60
  1. Centroid M400 code numbers
    By h_2_o in forum Centroid CNC Control Products
    Last Post: 11-06-2019, 02:33 PM
  2. G-Code 5 point star
    By seunao in forum G-Code Programing
    Last Post: 12-02-2008, 08:43 AM
  3. Maquining letters&numbers with single point maquining
    By ZeroDay in forum MetalWork Discussion
    Last Post: 11-24-2008, 09:43 PM
  4. How to get rid of line numbers in NC code
    By mcoughlin in forum CamWorks
    Last Post: 04-17-2007, 04:30 AM
  5. G-Code Line Numbers?
    By Imagineering in forum G-Code Programing
    Last Post: 08-17-2005, 01:26 PM
