Is there anyway to clamp the rpm on individual tool in the program on a Mazak 350 lathe.
Thanks.
Thanks.
If you're using EIA programs you should be able to do G92 (aternately G50 on some) for each tool.
if you need absolute control program with EIA/ISO G Code.
assuming Mazatrol, make a separate process for each tool.
rough od
rough id
finish od
finish id
etc
then try inserting a manual program before each tool with G50 Sxxx
Otherwise I don't think you can do it. You have to set one top speed to cover all tools.
