585,597 active members*
3,485 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > nm145 coolant pump replacement?
    Sep 2010
    72
    my nm145 coolant pump seems to have died (always right before a weekend...). I have warranty so i will contact novakon tomorrow, but if acklands has something in stock then at least I can use it this weekend as planned. Anyone replace the stock pump with something else and has a p/n or spec handy? (preferably from acklands
    thanks
    Jan 2011
    63
    I have had trouble with my coolant pump on and off for quite some time. If I don't run the machine within 3-4 days the pumps won't work.
    One of two things seem to happen. Gunk forms around the impeller or the shaft seems to stick. Both can be fixed by pulling the pump / motor out by disconnecting the connector and hose. The coolant box doesn't have to come out, just lift the pump up at an angle.
    Once out remove the few screws holding the cover of the pump on. Scrape any junk out then turn the impeller by hand until it is freed up.
    If you are running a water based coolant you may be able to use a submersible pond pump as a replacement and just drop it in the coolant box.
    Charlie.
    Visit http://www.shadowspawnllc.com to see what enhancements I have available for the NM-145.
    Sep 2010
    72
    Thanks Charlie. Turns out I overreacted, it was wiring. But I wouldn't mind hearing about a readily available replacement pump if anyone has used something successfully
  1. Replacement Chiller Pump
    By sdfoiler in forum Fadal
    Last Post: 09-05-2012, 06:00 PM
  2. 325 Coolant Pump
    By TurtleRacing in forum Tree
    Last Post: 04-02-2012, 07:51 PM
  3. coolant pump
    By JACKSMACHINE in forum Fadal
    Last Post: 05-22-2008, 09:13 PM
  4. TM2 Coolant pump
    By Peter Gibbs in forum Haas Mills
    Last Post: 05-03-2008, 06:11 PM
  5. Coolant Pump
    By Smackre in forum Mechanical Calculations/Engineering Design
    Last Post: 06-29-2007, 07:16 PM
