I have several Femco Durga 15E and 25E's and some were having problems where the X axis would not move in the positive direction while jogging. After tearing these machines down twice I have found that the tool setter has a four way sensor that had a switch still pushed in. I manually pulled the tool setter down while the machine was off and screwed with the switch until it came back out. Turned on the machine and it was fine. Apparently this machine was down for 6 months and had several technicians look at it and all it was was a hidden switch. Hope this helps you guys with these Femco's out there. :banana:
