I have a need to cut some slots for a lid to slide into.. they make tools for doing this but I can't figure out how to program it into deskproto, basically it's for cutting an overhang, I"m sure you get what I'm saying.
I went into the tool library and tried to add a tool, I set the cutter length to the 'thickness' of the slot cutter then set the flute length to the same, set the cutter diameter to the actual diameter of the cutting wheel and set the shaft diameter to what it is (1/8th).
When I did this, the little preview turned into a big red X. I have a feeling it doesn't know how to handle that set up... any insights?
