Originally Posted by
Goldhunter_2
*a mounting celvies (sp?) die.
* Now what I don't understand or comprehend is the maximum outward extended pressure a Pneumatic Air Cylinder What determines why one cylinder is stronger (provides more force) then another one? is it the amount of air psi provided to the cylinder or does it have something to do with the overall diameter of the cylinder it self (some are narrow some are wide)
Clevis?
You maybe need to take a look at basic fluid power, which is basically the same as pneumatics when it comes to understanding cylinder operation.
e.g. The force exerted by a cylinder would be the area of the cylinder x the pressure, e.g. a cylinder of 4" dia has a piston surface area of 12.57sq", if operated with a pressure of 80bls, 12.57x80 = 1000lb pressure.
Al.
Albert E.
