585,589 active members*
3,520 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Swisscam-trying to follow turn on an M20
    Oct 2012
    Turning a long (14"+) shaft with varying dia. Wanted to use the gang and turret simutaineously, each at a different diameter to speed things up a bit and extend the tool life a bit. after syncing the 2 processes and expecting to have 2 tool paths( one in $1 and one in $2) Partmaker gave me a combined tool path with the arguement G125 X1=X2 . it didn't run on the machine. lots of errors. I belive that this type of turning is called follow turning. Does Partmaker support this ?
    304
    Somehow you chose to "Mirror image" and that is why you got "G125"
    You want to use G720/G620 to "Superimpose" the 2 dollar signs onto one another. Then you will have the code you want.
    Oct 2012
    Okay. I did translate this first tool path (turret) by .268 to make the second tool path (gang). I did this in the CAD.I will try it without translating. I haven't seen any thing in Partmaker that allows me to specify G700 commands.
    Oct 2012
    When you said mirror, you meant G125. I see that now. Never knew there was such a G code. I am new to this profession. The problem was that Partmaker did not start the tools an equal distance away from their start points. I positioned them at the correct points and it ran just fine. If any one could point me to a comprehensive G-code list for swiss I would sure appreciate it.
    304
    On the process table, sync group. you choose how you want the process to run
    Choose 2 tools main spindle.
  1. Follow error
    By Lotusjohn in forum CNC Machine Related Electronics
    Last Post: 11-29-2010, 02:35 AM
  2. G65 and G74 in PartMaker SwissCAM
    By PACMan1779 in forum Uncategorised CAM Discussion
    Last Post: 03-27-2009, 03:50 PM
  3. Follow the money
    By dynosor in forum Environmental / Alternate Energy
    Last Post: 11-04-2007, 11:33 AM
  4. Follow Up Of My Cnc Put Together Now
    By chris69randy in forum DIY CNC Router Table Machines
    Last Post: 04-16-2005, 08:40 AM
  5. Please follow the rules
    By cncadmin in forum BobCad-Cam
    Last Post: 07-27-2004, 03:12 PM
