585,764 active members*
4,143 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Post For Mill Turn
Results 1 to 6 of 6
    May 2012
    Post For Mill Turn
    Hello Everybody,
    My company just purchased a Doosan 2100 SY with subspindle and Y axis. I am curious if anybody has a post processor for the machine it uses a Fanuc 31i controller
    Sep 2012
    255
    Quote Originally Posted by jonnyrocket56 View Post
    Hello Everybody,
    Your Surfcam dealer should be able to supply you with correct post file free of charge.
    If not, then you can use SPost editor to modify one of existing posts to work with your machine.
    Our company had a post done for our Okuma for free.
    May 2012
    I contacted surfcam but it will not be free of charge for a post-processor. I have never used Spost and the manuals are not friendly at all. Does anyone have a lot of experience with Spost and were did you find a good manual.
    May 2003
    70
    unless you know FORTRAN or are a wiz at coding, Spost is not easy to learn. Your best bet is to contact Paul Andrews @ Posthaste post processor (Home_ and upgrade your mpost so you can make your own posts.
    Sep 2012
    255
    Quote Originally Posted by Camfather View Post
    There is a graphical utility in surfcam package that allows to create and edit existing sposts. No docs needed, you just stroll through tabs and fill up fields like "coolant on code"
    All one needs to do is open existing fanuc lathe and add c axis.
    There might even be one like that in there already.
    Sep 2012
    255
    Quote Originally Posted by zero_divide View Post
    Go to Program files.
    Go to SURFCAM Tools
    Open Spost Configuration utility
    ...it loads...
    Go to open one of "Mills" samples (IE EXAMPLE: Millturn Post)
    And basically using common sense eter as many corrdct values into every field as possible.
    Might take a day or two to get it right, months to perfect it.
    B/C even posts you would order from SC are ...not perfect to say the least.
  1. UGS NX5 turn mill post processor wanted
    By CCLow in forum Uncategorised CAM Discussion
    Last Post: 08-05-2011, 02:43 AM
  2. Mill Turn post
    By phoodieman in forum Post Processors for MC
    Last Post: 05-13-2010, 01:29 AM
  3. Post Needed for Integrex e500H Mill/Turn
    By BWay in forum CamWorks
    Last Post: 06-02-2009, 12:34 PM
