585,973 active members*
4,084 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Configuration got corrupted, created a new xml file but par-port doesn't work anymore
    Apr 2006
    40
    I messed something up by trying to open a file before it was saved all the way, and the xml got messed up. So after wishing I would have had a backup, I attempted to just start from scratch, but now my par-port inputs do not work. I have verified that the base address is correct, and have ended up uninstalling and reinstalling multiple times, but to no avail. If I boot into linux, linuxcnc still works fine, so it is not the hardware. Any ideas short of reinstalling windows?
    CP
    Jun 2008
    562
    Quote Originally Posted by CptanPanic View Post
    CP
    I think if you look in the Mach folder there is a Backup xml folder(I think). The files have a different file extension though. Drag and drop one(from a time period that worked) up into the Mach folder and change the extension to .xml. If its your lucky day it should work. If it does work make a backup. Hopefully my mind remembers correctly.
    Good Luck
    Mike
    Apr 2006
    40
    Thanks alot, that helped.
  1. Replies: 8
    Last Post: 02-28-2011, 11:07 PM
  2. revive corrupted file
    By emsee in forum Mastercam
    Last Post: 01-09-2011, 06:34 AM
  3. Replies: 9
    Last Post: 06-15-2010, 12:52 PM
  4. BCC v22 Speed/Feeds corrupted if file saved without post
    By brooklynmetal in forum BobCad-Cam
    Last Post: 03-25-2008, 02:33 PM
  5. Help! It doen't work anymore?
    By boxwood in forum DNC Problems and Solutions
    Last Post: 08-04-2003, 06:29 PM
