Just trying to plan ahead with this one as I am not at work until next week.The job in question that I am doing we make hundreds of and the part no is manually stamped on a 100 mm dia. The part nos are about 15 digits long and the last no changes for every comp in that batch I e the first part would be
Abc...........1
Then
Abc...........2 and so on.
1st question is can you etch txt around a dia using a 4 th axis that I have(rotary)if so how ?
Also does the etching cycles on a hurco have a unit in winmax that will count up and auto change in the prog ie lat no change 1,2,3,4,5 and so on.
I think that the answer to both of these is yes,but I can't look on my mc until I am back at work next week.like I say I am trying to plan ahead.
Cheers in advance
