I have an servo pack of Yaskawa Servo Drive model no SGDH-10ADG with connected motor SGDM-08U3B4L my drive has been faulted and i want to change this inverter with any other make MITSUBISHI/DELTA while using the same yaskawa motor.
Is this possible.
Is this possible.
Where in India are you from ?
The best answer to your question can come if you take the motor to the Delta outlet near you and ask their engineer the possibility of inter using Yaskawa motor with Delta drive.
I personally think the outcome might be negative since its encoder and other properties might not match with the Delta drive.
What did the Yaskawa engineer say to you about repair or anything else?
