585,994 active members*
4,600 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Dwell within Cycles (G71 etc) for chip breakage?
Results 1 to 8 of 8
    Mar 2007
    22
    Hello,
    Friend has a problem when they turn plastic material in their lathes, they havent found a way to make the chips break, they've had to mill small grooves around the part to make chips break.
    I havent tried to give dwell motions within turning cycles, so i was wondering how different controls react to these?, though i havent turned nor milled any plastic myself and i doubt if even a little dwell would help with the problem?.
    I dont have the exact shape they try to turn, was only told that it's not for finished shape so any small errors are acceptable.
    Small simple example for fanuc..
    G0 X81 Z2
    G71 U3 R1
    G71 P1 Q2
    N1 G0 X50
    G1 Z-20
    G4 X1
    G1 Z-40
    G4 X1
    G1 X80 Z-60
    N2 X81
    Feb 2008
    586
    I use a G74 for straight cuts.
    G74R.003
    G74X(target diameter)Z(target length)
    There are two others letters used, but I'm not sure (from home) what they are, but they are for depth of cut and length before retract, and the first line R is the distance to retract after each advance. Works great to break up those plastic chips!
    Feb 2006
    1792
    I doubt if dwell would work inside G71. It is not mentioned in Fanuc manuals, nor have I tried this. If it does work, please let us know.
    2932
    Apparently you can include a G04 within the finish shape definition.
    Attached Files Attached Files
    Feb 2006
    1792
    I believe G04 would be used by G70. but not by G71. Somebody may try and confirm.
    Mar 2007
    22
    Actually tried the dwell motions within G71 cycle and it worked, though i only had one cut and used simulation. Have to try again with multiple cuts on same cycle, and see, if it only applies the dwells on final cut.
    One can always break the profile in multiple parts with cam, and do multiple cycles, but i wouldnt count that as solution if your doing multiple different parts, would have to find a way that can be applied easily while hand programming.
    Thanks for replies, just seemed bit extreme solution to mill grooves for chip breakage, but then again i have no experience with plastic. And always trying to learn something new
    Feb 2006
    1792
    Quote Originally Posted by mystiks View Post
    This is what I suspect.
    G71 may ignore G04 while roughing, but consider it during the final step-removal operation.
    Simulation cannot be relied upon 100%, especially if it is a third-party software.
    Mar 2006
    21
    Quote Originally Posted by beege View Post
    G74R.003
    I have used this method also for machining copper, tantalum, Niobium. The concept of breaking a chip is in another world.
    G00X5.1
    G74R0.005
    G74X5.1Z-0.105P0000Q0150R0.010
    G0X5.0Z-.75
    G01
    G74R0.005
    G74X5.0Z-.105P0000Q0150R0.010
    I called it a stutter cut
  1. Tool Breakage Detection options
    By dak1 in forum Uncategorised MetalWorking Machines
    Last Post: 10-12-2012, 03:28 PM
  2. Tool Breakage Detection
    By dak1 in forum CNC Tooling
    Last Post: 04-03-2012, 03:55 PM
  3. ATC Arm breakage!?!
    By Shotout in forum Okuma
    Last Post: 01-18-2011, 04:00 AM
  4. 4-40 Thread Forming Tap Breakage
    By secretpickle in forum MetalWork Discussion
    Last Post: 05-11-2009, 02:07 PM
  5. Retention knob breakage
    By Crash in forum Uncategorised MetalWorking Machines
    Last Post: 11-03-2005, 09:12 PM
