585,591 active members*
2,519 visitors online*
    Sep 2006
    19
    Copper to copper Welding
    Hello,
    i need help for Copper to Copper welding, not brazing..
    pipe Dia 4inch, and sheet, welding full round, nonstop i am try to welding arc but finishing not good,
    Apr 2010
    20
    we figured out how to tig weld sinks made from copper sheetmetal years ago. I dont remember the grade but I want to say it was "oxygen bearing"
    anyway, shearing 1/16-3/32" strips from the same material and using it as the filler rod. using the "pulse" function on the machine, zapping it with short spirts and high amps along with high purity argon made some really nice, strong welds. we would then grind and polish the external welds resulting in perfectly matched color between base metal and weld
    myspace.com/1metalmorphose
  1. copper?
    By bowhunter in forum MetalWork Discussion
    Last Post: 04-26-2007, 06:41 PM
  2. Copper Vs Carbon
    By JIMMY in forum Material Machining Solutions
    Last Post: 10-26-2006, 01:46 AM
  3. what tip to use for copper?
    By HawainPand in forum MetalWork Discussion
    Last Post: 09-22-2004, 09:30 AM
  4. Copper milling
    By eponyme-le in forum Uncategorised MetalWorking Machines
    Last Post: 06-11-2003, 08:07 AM
