585,992 active members*
5,178 visitors online*
    Aug 2007
    422
    Question 12mm EPP Issues
    I am trying to cut 12mm EPP and can't seem to get a quality cut. I am wondering if anyone on here has or is cutting 12mm or thicker EPP and how they are doing it. I was attempting on a laser but the burn is inconsistant and the overmelt and kerf is unacceptable. I tried several power,speed settings and air pressures to no avail.
    Anyone care to provide some input....
    Necessity is the mother of all invention (unknown)
    My club home page www.lhmac.org
    Hello,
    how does the problem look like?
    To get good results in EPP you'll need sharp tools (never use them on anything else before), as high as possible rpm and the flutes of the tool should be straight.
    A large tool diameter also helps - if the tool is too small it will start ripping out EPP beads very soon and may break once it heats up and gets wrapped by molten EPP.
    However the surface will always look a bit felted unless the tool is razor sharp.
    Christian
    My CAM Software and CNC Controller: www.estlcam.com
  1. 12mm X1mm nuts needed
    By Marzan in forum DIY CNC Router Table Machines
    Last Post: 11-11-2008, 03:56 PM
  2. Need two 12mm 4 Bolt flange bearings
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 10-30-2008, 07:30 PM
  3. Where can I find a 12mm 2.5 pitch lead nut
    By woodturn in forum Benchtop Machines
    Last Post: 03-14-2007, 05:17 AM
