Deflection is going to be a killer on that deep a slot with that tiny cutter. I'm not sure based on the numbers I see that even fizzissist's strategy will work with EM's this small and that much stickout.
Gonna be a hairy job that'll take a lot of light passes to make it work. The numbers from G-Wizard suggest no more than 0.002" deeper each pass. EDM might be faster at that rate.
It might also be worth a tool change. If you run one EM with 0.2" stickout it can go 1/3 diameter deep passes down to 0.2'ish depth. Then switch to one with more stickout and make shallower passes.
Best,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
