585,973 active members*
4,182 visitors online*
IndustryArena Forum > CAM Software > PowerMILL > Powermill and Mach 3
Results 1 to 6 of 6
    Jan 2008
    106
    Arrow Powermill and Mach 3
    Is it possible to run Delcam Powermill made g-codes on Mach 3 without errors? Or is it that I will get errors and I have to build a post-processor according to my machine co-ordinates and function?
    Anyone is using Powermill made g codes on Mach 3?
    Oct 2012
    25
    powermill for mach3
    Hi.
    yes certainly it is possible to generate a g-code without error for any controller either mach3.
    I can write post processor for any type of 3 axis and 4 or 5 axis for mach3 , so that the g-code will not need any edit and directly will be start on Mach3.
    For details & costs send your machine information to my e-mail : [email protected]
    Nov 2010
    10
    Losing Bearings on Tool change
    I am using Powermill and Mach 3 on a Novakon Torus mill. I am making a simple 2 1/2 D part with a profile and some holes drilled in it. When it comes to a tool change, it seems to lose its coordinates and wander of in to space. Has anyone had this problem?
    Feb 2011
    212
    Re: Powermill and Mach 3
    I will be needing a post for mach 3 soon as well any help
    Oct 2012
    25
    Jun 2017
    4
    Re: powermill for mach3
    y send to you an email
  1. need 2 powermill experts in SE
    By BILL WRIGHT CCR in forum PowerMILL
    Last Post: 01-09-2014, 12:08 AM
  2. powermill help
    By FandZ in forum PowerMILL
    Last Post: 05-24-2009, 04:25 AM
  3. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
  4. PowerMill question
    By Dan B in forum Uncategorised CAM Discussion
    Last Post: 04-07-2006, 07:22 PM
  5. PowerMill and 2D
    By georgebarr in forum Uncategorised CAM Discussion
    Last Post: 03-31-2004, 05:56 PM
