I'm using this driver http://files.panucatt.com/datasheets...user_guide.pdf
which says it supports up to 2 amps and up to 35 volts max (with additional cooling). Its typical to use NEMA 17 motors with these drivers but I would like to run one axis of a 3d printer using a NEMA 23 motor so I can get higher torque. The problem is that I don't know enough about steppers to know what is good and what is bad. I need it to run fairly cool as they are mounted using ABS brackets.
Here are the stepper options I'm looking at 57BYGH402
What factors are important to consider? I'm really interested in the 57BYGH301
2 phase
5.88 volts
1.4 amps
4.2(O) resistance
15mH Inductance Phase
15 Kg./cm Holding Torque
That seems like a good option, but all of this almost seems to simple, that is nearly 3 times the torque of my current NEMA 17 steppers. Am I overlooking something?
Please let me know
Clay
