586,024 active members*
4,275 visitors online*
    Noquarter Guest
    Metric to Inch
    Hi there! Wanna move from europe to Canada perhaps to US and my wories are to get used to Inch programing. Im 10 years exp. CNC operator (toolmaker) never working with Inches. Can you guys give me some helpfull advice how to easylly learn my brain work with this? thx!
    Jan 2006
    2985
    25.4mm = 1 inch
    DONE!
    For ballpark figures, an inch is about 25mm and 1mm is about .040"
    I've never understood the inch/metric standoff. Just convert and you are good to go. The machine is not really going to care, it's just numbers to it.
    Matt
    Jun 2007
    3757
    It's only the microns the brain has to deal with. It it not good for your imagination.
    Looks like you might now use 25.4mm and 9.52mm cutters. It is just a number.
    Just becoming accustomed to the standard sizes used. It is very dependent on the industry you are in, for what you will find/come up against.
    Just think in metric and write in inches.
    Apr 2010
    294
    It's not too bad if you're working in Decimal inches.
    I tend to think 0.004" = 0.1mm and 0.01mm = "half a thou", but I'm not working to finer tolerances.
    But you can get brain ache with drawings in fractions 23/64" etc.
  1. Fanuc 6t Metric to Inch ?
    By denverwelder in forum Fanuc
    Last Post: 09-01-2016, 09:14 PM
  2. Should I design in Metric or Inch?
    By jupdyke in forum Mechanical Calculations/Engineering Design
    Last Post: 08-18-2011, 05:48 PM
  3. Metric to inch conversion
    By BobF in forum Mach Software (ArtSoft software)
    Last Post: 12-28-2007, 05:53 PM
  4. DRO - Metric or Inch
    By DJ Morrow in forum CNC Machine Related Electronics
    Last Post: 11-15-2004, 09:06 PM
