585,602 active members*
3,468 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > I Need a Yoke (and/or dims) for a Bridgeport
Page 1 of 2 12
Results 1 to 20 of 25
    May 2005
    1810
    I am looking for a heavy XY nut bracket (yoke, dog bone) for a Bridgeport. I would also like to get a dimensioned print for same.
    Any ideas? I have checked E-bay - they always seem to be available until I need one.
    Do any of you have one you'd like to unload? How about a print?
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Dec 2004
    293
    Scott, did you check out Elrod machine? They have one for their screw retro fit. I have been working with my Rockford retro yoke and it seems to be OK. They have a funky bolt pattern on the Y axis though. Three bolts and one is off like 30 degrees...? Odd.
    I was initially concerned about it. But, if you have seen the pics of my parts, things are working well. I raidused a .1875 r arc with a .25 dia cutter and it's smooth. Repeated the feat six times.
    I was also initially concerned about the rolled screws, but again, all is well so far.
    I want to keep my old yoke, sorry.
    Hope that helps.
    -jd
    John Delaney
    www.rwicooking.com
    May 2005
    1810
    Long read - sorry. Could use a hand here....
    Thanks for the reply, JD. I recall you installed rolled Rockford screws, right? Do they offer ground screws - just for price comparison - or only rolled? I am not stuck on ground - depends on the cost difference.
    If you have gone through the ball screw thing for a BP - please read this and help me choose a direction, would ya? Many, many thanks.
    I realized last night that a stock yoke would not work for what I was planning so now I am in a serious debate here.
    I have a perfect NSK ball screw assembly to fit the table but I would have to shorten it a few inches and machine and grind one end, then modify the table mount and yoke. I have the capacity but it would tax my equipment and set-up would be a challenge. I also have a very stout THK ball screw assembly for the saddle but the same holds true - lots to modify and machine. These screws were not made for the BP mill - they are out of industrial equipment that was recently scrapped where I work but both are .200" pitch and appropriately sized for BP use - I lucked out, but they are not drop in replacements. I have three screws total - all are complete with thrust bearing mounts on one end (very similar in size to the standard Bridgeport mounting arrangement but with 4 bearings in a self-contained housing - nice) and appear to be in very good to excellent condition - they were in a clean room environment.
    After reviewing all that's involved, I think it's going to be too much time and too much trouble to make these screws fit the BP correctly. I would have to fabricate a yoke from scratch and while this would be possible, it's a lot of high tolerance work and requires tearing down the mill and getting measurements then re-assembling the mill to do the machining with some outsourcing likely. The cost of getting the screws I have to work would likely be more than just buying a set or a kit ready to go.
    So - I am searching for a ball screw retro kit.
    The players for a complete kit are:
    Rockford
    Hiwin
    Elrod
    Nook
    Roton (I don't think they make a kit, though??)
    McMaster (looks like Mcmaster sells Rockford screws)
    Wedin
    Rockford is the only one that has replied to me so far. Currently waiting for a quote from my local supplier - Motion Industries.
    Hiwin stuff sounds good but you have to jump through hoops to get info - why cant these people make their products easy to understand and purchase? Should I bother with the tricks to get info? (you have to fax them on a form that has absolutely nothing to do with Bridgeport retro-fit kits - why can't they handle a simple E-mail? Is that really all that difficult?)
    I saw the Elrod yoke but I think their website stinks for info and I can't gather enough info to feel warm and fuzzy. They have not replied to my direct questions, either. I think I would really like to have the Elrod yoke - it appears MUCH stronger - and they offer ground screws with an attractive accuracy claim - but their sluggish response and cruddy web site has me a bit concerned. I do think they are the front runner right now, but I want to see their quote. I am leaning towards going with them. Maybe I should place a call....
    I have requested info from Nook - no response at all yet.
    It looks like McMaster carries Rockford - is that correct? $650 for a set of rolled screws and a yoke - ready to bolt in.
    Wedin - claim to have a kit, but no info on their site. I e-mailed them but no reply yet.
    Are there others I should investigate?
    Rolled for me would likely be fine - as long as I can get rid of backlash so that I can profile and pocket without all the issues from backlash. I intend to use the machine to cut injection molds in the very near future (if possible) so accuracy is a requirement.
    If I am going to spend close to $1000 for screws, I would be tempted to throw a bit more in and get the best stuff I can at the moment.
    Thanks for the shoulder, guys. I needed to get all of this off my chest! I feel better now.....
    :wave:
    Scott
    Oct 2004
    832
    Modifying the yolk to suit may not be a huge problem, in fact you may not have to modify at all. I havent had time to read your post through as I am going out for a while but I will read when I get back in half an hour or so. In the mean time if you have pics of your ball screws it would be good to see what the nuts look like.
    Hood
    Dec 2005
    3319
    HIWIN offers JPG's with full dimensions for their screws on their website as well as lead specs of rolled vs ground. Call them at their office (phone is on the website) and ask for tech support. I got thru to an engineer at first call and he didn't have me jumping thru hoops.
    For backlash, simply install true, machine tool grade ball screw support bearings. Pricey but well worth it. You do have to make some shims but it is easily done with some lazer cut shim stock (oem BPT bearings are oddball width) but easy to deal with.
    We've got nearly 0.000 baclash comps and measure roughly a net 0.0001 "blip" at direction changes when outside circle cutting. We we measure the deviation with our cam measurement equipment
    Our screws are OEM supplied rolled threads from HIWIN on a BPT "EXTRAK". Briian at BPT Machine in Carol Stream Ill did the servo tuning.
    May 2005
    1810
    Ah - two of the guys I wanted to hear from. Hood and Cams!
    Cams - if the stock BP bearings are loose when I do the retro, why could I not fit a quality set of tapered roller bearings in place with adjustable preload via a nut or a pre-ground spacer? Do you think this would be a bad way to go? The screw's max speed will be well within the rating for the bearings - what are your thoughts on using taper roller bearings for this?
    Hood - the screws I have are fitted with nuts that are larger than the yoke will permit. They are substantially heavier than the BP nuts - I am sure that I would have to make the yoke myself. I was looking mainly for a few of the dimensions from a reliable source so I would not have to take my mill apart just to get a few dimensions.
    Thanks for the posts, guys! Looking forward to your reponses...
    Scott
    Oct 2004
    832
    Quote Originally Posted by mxtras
    Scott
    Still not read your post yet but when you said the nut was larger than the yolk I thought I would post a pic of what I did. I basically made a part that was the same OD as the original brass nuts, keyway in it and thread on the end, on the other end I had a lipped flange to accept the ball nut. Slipped it through the yolk and screwed a nut on to lock in place, put the yolk in the mill and then from the front I fixed in the ball screw and secured with the cap screws. Not very good at explaining but the pic should help you follow what I am saying.
    Dec 2005
    3319
    Re: tapered roller option or several reasons for NOT using tapers as a ball screw support bearing.
    1. friction
    2. package size
    3. axial runout
    Some of the taper axial capacity comes from rolling resistance of the tapered rollers. BUT some also comes from sliding friction of the roller sides against the flanges. Common trick in racing axles is to replace tapers with A/C balls - reason, to reduce fricion albeit at a loss in fatigue life due to lower capacity.
    To get ZERO to negative axial clearance with a preload in a taper, you WILL have more rotating torque that with a preloaded ball. In my case the OEM ball bearings (modified 6204s) had something like 75lb preload. We replace them with 480 lb preload A/C true ball screw bearings. The A/C bearings take LESS torq to turn the handles than the OEM's.
    Although you might find a taper that will fit (ID and OD) in place of the ball type, the axial width is probably gonna be wider - getting two with comparable radial runouts is gonna be even tougher. They may tend to radially "fight" each other when packaged in DB mode.
    Yes, you can mess with different bearing retainers and other mods to fit T/R's in place of the balls but compare that to a "bolt in" ball bearing DESIGNED to do what you want/need to do. No comparision.
    You are looking for minimal AXIAL RUNOUT in a ball screw bearing. Most tapers are NOT machine tool grade. Since radial runout of a taper does affect axial runout, it is another issue to have to deal with. Yes, there are M/T grade T/R bearings but they are not easy to find.
    When you add up all the compromises, it doesn't make sense (to me) do do anything but install ball screw bearings.
    NOTE: having been involved w/ball bearing engineering for a number of years, I know more tricks than the average bear about how to cheat up and use bearings in unique ways.
    When it came to trying to tune up my BPT/Eztrak, I simply bit the bullet (teeth still hurt) and bought the proper bearings.
    When you buy the best, you are seldom disappointed.
    May 2005
    1810
    I agree that you get what you pay for. I only know enough about bearings to be dangerous - it sounds like you have your act together with a lot more experience with precision rotating things than I.
    Elrod responded - no yokes are available at the moment. Their screws are ground and are quite a bit of cash. I need to contact Hiwin. Hopefully today. - - - UPDATE - Elrod screws are made by Hiwin - confirmed by Elrod.
    Cams -
    My current screw arrangement (factory BP installation) has Fafnir 6204 KTT restrained on the left side of the machine only - the right side HAD an aftermarket power feed and the bearing was not captive. Should I conserve the arrangement and leave the float in the right end of the screw? If so - it places a lot more emphasis on the 'play' in the only thrust bearing on the other end of the screw, which concerns me.
    What 6204 is highly pre-loaded? I ask because I am in the midst of designing and machining the right side drive bracketry and am currently working on the bearing retention. I could use your design guidance here.
    Thanks for the experience, Cams.
    Scott
    May 2005
    1810
    OK - One issue resolved!!!!!
    I called HIWIN and spoke with Jason in engineering. He was extremely helpful, answering all but one of my questions.
    I have decided to get ground screws direct from HIWIN. The price of the ground screw kit was substantially less than I expected!
    They do not, however, offer a high quality bearing option. He did clarify that the factory installation was held on one end and floating on the other and he seemed to think this was acceptable.
    So - I guess that I need to find a really good bearing for the left side of the table screw and I am good to go for the table. HIWIN does not offer the bearing and Jason did not offer a recommendation.
    Scott
    Dec 2005
    3319
    Scott: Here's what to do:
    Buy two sets of 24TAC47BDFC10PN7A bearings from NSK. Hold your breadth when you see the price but they are worth every penny/yen.
    Replace left side X axis dual bearings - the other end is OK as is. You make have to make an OD shim to make up the difference 'tween the OEM and the above ball screw bearings. Insert shim between bearing retainer and outer race of bearing that would touch the bearing.
    Repeat operation for Y axis.
    Reset backlash and lead comp if you have a computer hooked to the system.
    If you get preloaded ballscrews, you should have no appreciable b/l to deal with. Ours is under 0.0002 and if we take our care, we can see less than 0.0001 of a "flat" at direction changes.
    Don't forget to spend a number of hours adjusting your gibs, too, as this will also affect B/L and lead slightly.
    Drive wise, drive on the side of the ball screw suport bearings (left side of X axis and you don't have a choice for Y). Provides for more rigidity as you can't stretch the screw as easily.
    May 2005
    1810
    Excellent - I will dig into obtaining these bearings.
    * * * * EDIT * * * * * * * * * * * * * * *
    The recommended bearings: NSK# 24TAC47BDFC10PN7A
    The bearings I was looking at: NSK# 20TAC47BDFC10PN7A (direct replacement)
    The recommended bearings appear to be over $475 each. OMFG! I was expecting maybe $150 tops. Can't do $950+ for two bearings. I know there is a difference, but I can not justify it based on the relatively minute benefits.
    I will have to deal with .0003" backlash* from the set of angulars that came on the mill. I will replace them but it will be with a new set of the same bearing.
    *I will measure the actual bearing slop in my current set of used bearings tonight and report back.
    Thanks for the info and for the help. It's much appreciated. I will post any remaining info either in this thread or in the thread about the mill conversion.
    I may start a new thread about the ball screws, yoke, interchange details and what I have learned from this experience as well as what I did to achieve whatever results I end up with.
    Scott
    Dec 2005
    3319
    SORRY for the transposed digit. IT was late in the day when I responded. Told you they'd be pricey....
    Don't replace with same OEM"s as you're probably not gonna improve much if at all. We had 0.0005 or more B/L under load and ours were like new.
    Try this instead: 2 @ 7204B per screw. Look for ones with plastic cage instead of riveted cage as they are easier to rework (see below).
    Send them to KAF Manufacturing (Stamford CT I think) and have them preloaded to about 250 lbs in DF configuration. They'll regrease them also if you tell them what they're gonna be used for. Or shim them as outlined below.
    7204B's Should cost you less than $475 each (guesstimate) but A/C's are pricey regardless of the heritage. This option should perform better than the OEM replacements which aren't going to be cheap either as they are special preloaded 6204's. Besides, the new OEM's won't be as rigid/backlash free as the preloaded 7204B's or the 20TAC47's I'm describing.
    As a final thought, make some shims out of aluminum foil (as in Reynolds wrap)and evenly increase the preload of the factory bearings. Pretty sure you shim the OUTER rings. Do it in stages as load increase is NON-LINEAR.
    Once you find a shim that is acceptable, have some cut from hard shim stock (lazer cutting is deadly accurate and not that expensive). Rotating friction will be higher but you'll see a noticeable difference in the backlash....
    Dec 2004
    293
    Wow! Yeah, what he said! ;-)
    Well I was going to say give Elrod a call. Duayne is a good guy. I probably spelled his name wrong but oh well. Surprised he doesn't have any yokes. Wonder if he supplies Hi Win. He does supply a lot of people with stuff. He's kinda the source for Z drives for several retro fitters too.
    Yeah, McMaster sells Rockford.
    Maybe my machine is a P.O.S. but there is no way on this planet I can get it to within .0003 in any direction for any reason on a consistent basis. I would have to have it completely overhauled and re-scraped in. Even then I think on the extents of the table travel in X there is too much mass hanging off the saddle and not enough saddle to prevent some sag. Maybe if I focussed on a small area in the center of the travel.
    Then a bus goes by and it all shakes! I HATE that.
    Then once my garage swings from 67 degrees in the a.m. to 80 degrees in the late afternoon, forget it. It's gonna expand .005 across the table, at least. The dumb encoders aren't going to know that either so there I go. The vise is going to swell and contract .002 to .003 just on it's own.
    But I am getting .003, as long as the temp is steady and no buses, I think I can say with some confidence. My backlashes are .002, .003, and .005. I need to check that again after a while of course.
    Still, the parts look pretty good so far.
    I am using 7204Bs. They were like $80.00 each I think. I would have to have a darned clean Bridgeport to drop $450 for a bearing. Even then with the thermal issue I'm not sure it does a lot of good.
    How much were those Hi-Wins? I might go that way on the next one just 'cause I don't think they are that much more than the Rockfords. Did they sell a yoke?
    -jd
    John Delaney
    www.rwicooking.com
    May 2005
    1810
    I was told HIWIN supplies the screws to Elrod. And yes - Elrod is out of yokes. The guy that supplies their castings retired and the company he worked for is no longer in that business. Elrod is not sure if they are going to even get back into dealing with the yokes. Elrod's quoted price to be this morning was $1525.00 for the ground screws and a "universal" yoke - nothing fancy but is supposed to be stronger than the stocker. Elrod has screws in stock.
    So, I called HIWIN. They quoted me under $1000 for the ground screws and a "universal" yoke - the same thing as Elrod - but for $525.00 less. HIWIN is currently out of stock as of this morning. They expect more in soon. HIWIN is at the top of my list right now.
    The Rockford screws are sold through McMaster and are rolled - they go for $650 with what appears to be a "universal" yoke.
    I can not locate a heavy duty yoke. Elrod was it. Bummer.
    This is all the pricing and info I have so far. It seems like the other companies I contacted just do want to sell their stuff. I am waiting to hear back from a few others. If I hear back from any of them, I will post my findings. In the near future, I may sit down and copile everything for others to reference in the future - all the info is here in this thread, but it's quite scattered and diluted. Having all the info in one convenient place would be - well - convenient!
    I measured the slop in my stock BP screw support bearing tonight. I have one more thing that I need to do to confirm my measurements so I am not going to post the results just yet. Let it suffice to say that it's not as bad as I thought it could be but it's enough to worry about in my mind - especially since I intend to install ground screws. In it's defense - it is an old bearing with an unknown history. I have another bearing (not new either) that I want to install and check as well as perform another round of checks to nail down exactly what is moving and exactly how much.
    Tonight's tests were performed using a brand new Browne & Sharpe test indicator - straight out of the box. It has a .002mm resolution (2 micron, .00007887") - I think this will tell the tale quite well.
    I was measuring from the table to the screw. Tomorrow I will also measure for bearing mount deflection and I will be using a torque wrench so that the checks can actually mean something in regards to force exerted during the tests. I think this will be very helpful information.
    More info tomorrow night.
    There is no doubt that to get super tight tolerances you would need to be in a climate controlled facility with a good isolated foundation. I have neither for my machine so spending another grand to chase something I really can not attain just doesn't make sense. It would be nice to say that I have a near-zero backlash machine, but it 'just aint not happnin'. I will be satisfied to get what I get with reasonable efforts using affordable components. I think I will see less than .0015 for less than $1300.....you have to spend more to get less. I will try to shim out a set of 7204Bs and see where that takes me.
    Thanks for the insight, Cams. I really appreciate the effort you put into being clear and complete with your posts - and I am sure others do as well. Thank you. I may have more questions for you in about 3 weeks.
    Scott
    Dec 2004
    293
    Thanks for the pricing info. For what I got I think I'm OK. But for the extra few hundred bucks I'll likely do the Hiwins next time too.
    Guys, great thread by the way.
    Best,
    -jd
    John Delaney
    www.rwicooking.com
    Dec 2005
    3319
    We shimmed the "stock" 6204's and got well under 0.0005 b/l under load The only problem was rotating torque to turn the screw - it got REAL high.
    The 7204B's should do better, even with shims, than the OEM's as you're going to be loading the balls in an area of the raceway where they are designed and made to run. THus, more chance of ROLLING friction.
    The neat part about the B's is that they have a 30 deg contact angle. The 20TAC47s's have a 60 deg angle. HUGE stiffness for the TAC's albeit with a high price. The B's will be stiffer than oem 6204 balls due to higher contact angle potential.
    Check out the price of 7204A5TYDUHPA7 or P4. These are 25 deg and ABEC7. Might be more affordable than the TAC's as more are made/used and there might be more price competition. Install them in DF configuration.
    If you can get any form of a 7204A5TYDUL, M oe H bearing in a PA7 or P4 grade as surplus, you can have KAF preload them to suit for a nominal fee.
    May 2005
    1810
    Wow. Do you pull these numbers of the top of your head or do you have a cheat sheet?
    Great info on the options - I was focusing my attention to the higher contact angle bearings - sounds like I can use lower angles with a little TLC. That's good to know - thanks.
    I will look into all of this while waiting for my tax return.
    Scott
    Dec 2005
    3319
    Mostly from memory - occasional book perusal.
    When you've done bearing engineering for a living and learn the P/N sequences, some things are hard to forget.
    May 2005
    1810
    Well - my taxes are done. It's a matter of time before the ball screws are ordered - probably about 2-3 weeks (tax refund in hand).
    Not having the actual screws on hand is slowing down progress on the motor mounts as there are some differences in the shank of the screw. These differences would not effect a standard installation, but I am supporting the screws on both sides of the drive pulleys and therefore holding on a surface that is not used for the standard installation (for the table). Confused? Me too.... (nuts) I have to get the screws and then grind one diameter down just a bit to accept a support bearing (not thrust).
    At this point, I am still planning to use the 'universal' yoke that is supplied with most kits. They all seem to be the same, or at least equivalent. I still can not locate a HD version - Elrod is out and it doesn't sound like they will be back in production any time soon - if at all. It sounds like that era has ended. Someone should think about picking up the pieces and bringing back a HD nut bracket for BP and clone mills....
    The players for a complete ball screw kit are: (pricing as of Jan, 2006)
    Rockford - replied first, sell through Motion Industries. I believe they are rolled only. Did not pursue pricing as they are sold through McMaster.
    McMaster (Rockford screws) - $650, rolled screw kit with universal yoke
    Hiwin - called, spoke to Jason in Eng - excellent customer service, excellently priced kit - ground screws - buy direct from factory. Temporarily out of stock as of a few weeks ago. Right now - these are the screws of choice. Comes with a universal yoke but no thrust bearings. Under $1000 - for ground screws!
    Elrod - called, friendly service - ground screws with universal yoke, but no HD yokes available - may not ever be available again from Elrod. A bit pricey. Elrod's screws are made by Hiwin! No bearings. $1525.00
    Nook - never replied
    Roton - never replied
    Wedin - never replied
    Hiwin it is for me. I will keep everyone posted - likely in a new thread as I have noticed that it is sometimes difficult for me (and others, I am sure) to locate info buried in obscurely titled threads - such as this one....
    Jury is still out on the bearings - research continues. I still need to post the info about deflection and backlash. The bottom line is that the stock BP thrust bearing mount flexes under load - before the gib lock lets go. I have the torque values on these points. The mount flexes almost as much or more than the bearings have lash. A very surprising find as I have never heard anyone discuss this possibility before. It is there, and it is fairly substantial in a super-precision way of thinking.
    I will post up the test procedure with photos and the data when time permits. I still have not compiled the data. Time is not being nice to me these days!
    :wave:
    Scott
Page 1 of 2 12
