This can be true, if you screw up the default XML file for the machine definition you can " break" the software ,it will not simulate or post.
If you want to "Fiddle" with the machine definition as you put it, it's recommend that you do not work on the default setup.
Create a new one and "play" with that one. There is a lot of information in the help files that talk about machine definition and simulation. There are tutorials that cover building a machine and setting it up.
At this time BobCAD CAM software is a little more sophisticated and may take time to learn how to setup for 4 axis + . If you work with the defaults, you should not be having any issues. If you are having issues you need to report them and or call tech support.
It can be frustrating for all of us, but the new features we offer now will more than make up for the setup and learning curve.
It's new and we are all learning the system. If you are worried about production time, only use the new build on a back up seat and not the production computer.
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
