I'm in the process of retrofitting a knee mill and I'm starting to consider using the Kflop, but I have a few questions.
1. I have some custom servo drivers of my own design that I'd like to use. They accept a PWM 0-100% duty cycle input and a direction signal. (And yes they really do go to 100% since I'm not using the typical chargepump type gate driver for the high side Fet's.)
I'd like to just connect the encoders to the Kflop and then output the PWM and dir on just two outputs. Does Kflop support this arrangement?
2. I really need to be able to do rigid tapping. I plan to Use a VFD to drive the spindle motor. Can I get away with adding an encoder to the spindle and have the spindle switch from spindle to servo mode? If so, any recommendations on a VFD and encoder combo that wont break the bank?
3. I plan to do most of the Z-motions with the Quill, but am setting the knee up to be driven as well. I anticipate using to knee during tool changes and to set workpiece and tool height offsets. Does Kflop have any issues with this arrangement?
4. I plan to use Mach3 and may still want to use another I/O solution alongside the Kflop for some of the simpler things, is this a problem?
Thanks.
Marvin
