Universal Type Lathe CNC Controller is two axis mature ,more stable and reliable CNC control system. Execute international standard G code. Additional function: support external handheld box operation, additional panel, USB disk, USB communication.
Lathe CNC Controller function:
The controller adopts 32-bit high performance CPU and super-large programmable FPGA, real-time multi-task control technology and hardware interpolation technology, realizing the high-level precision motion control, and the highest speed can reach 12m/min;
X and Y axes stepper/servo control, capable of performing single-stage motion or continuous motion;
All Optocoupler isolation inputs and outputs, realizing a stable and trusted system;
256M electronic hard drive, satisfying the processing of workpiece with all kinds of large programs;
Capable of reading USB disk, which can be simulated as electronic hard drive to read, edit, and process the data; it is convenient to use;
With USB, COM communication control function, realizing the data transmission between PC and CNC controller;
Support additional panel, and handheld box operation;
The system adopts tutorial programming, executes international standard G code, and holds several functions such as thread tapping, too-change, linear interpolation, circular interpolation, backlash compensation, and electronic gear;
Open CNC platform, capable of custom-tailoring private system according to the specific requirements;
Capable of remembering coordinates in case of power down during the processing;
With complete and intuitive system reflecting the system operation status, users can discover the problems and do troubleshooting easily
