585,685 active members*
4,921 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > wiring tamagawa drivers to mach3
Results 1 to 18 of 18
    Mar 2009
    90
    Hello
    I have 3 AU6550N2062 DRIVER ser. no. 20716 with 3 TBL-i series AC Servo Motor TS4513N1820E200 600W 200v S/NA14253. I attached the manual for them.
    Need to set them so they can work with step/direction signal's from mach3.
    I don't know exactly what i did wrong but the motor is turning half a revolution only in one direction and it's go offline.
    I set the step to - forward pulse and the dir to - reverse pulse. The + forward pulse, + reverse pulse signal ar wired together to +5v com pin to the breakout board (c23 multifunctional board from cnc4pc)
    Attached Files Attached Files
    Dec 2003
    24220
    Did you try Tamagawa support, their support has replied to me in the past.
    Al.
    Albert E.
    Mar 2009
    90
    I tryed....no replay(
    Sep 2019
    Hello Al_The_Man. a seperate question, can I run a TS4513N3034E200 with a AU6551N286E815. cause originally the AU6551 was driving a TS4514 motor (800 W) and now with TS5413 (600 W).
    I have already have the motor and driver connected and seems to be running fine. Just your opinion if it will be durable?? Thanks.
    Franklin
    Apr 2020
    9
    Re: wiring tamagawa drivers to mach3
    I know it is far too long since the original post, but I did have a hell of a time finding the manual required for this setup AU6550N2041 DRIVER / TBL-i series AC Servo Motor TS4513N1820E200 600W 200v.
    Hope this helps someone get their setup running, I have an old ZEVATECH FS730 - Juki KE 730 pick and place machine, which I sources locally from a bankruptcy auction, I'm pretty sure it will be a great enclosed CNC for my kids' new garage based guitar factory, I've been playing with this setup for a couple of days, and have since managed the servos to move in the desires direction, although I'm still far from tuning them, any help would be really appreciated.
    Driver manual pdf size is 38+ Mb, so I couldn't upload it, I will link to my own website instead.
    Link to the manual files:
    Index of /servos
    http://bikeslayer.xyz/servos/AC_servo_specsheet.png
    http://bikeslayer.xyz/servos/AC_serv...al_1525n4e.pdf
    http://bikeslayer.xyz/servos/AC_serv...550_MANUAL.pdf
    Dec 2003
    24220
    Do you have the motor and feedback phased right?
    Are you using supplied cables or did you make them up?
    Try a simple analogue signal with a pot into the analogue input.
    Al.
    Albert E.
    Mar 2009
    90
    Al.
    Servo motors and drivers ar from a working machine, all the cables ar original.
    Jan 2009
    334
    Page 9 External Connections
    Quote Originally Posted by mecanicu View Post
    Hello
    See page 9, External Connections. Page 9 shows "forward pulse, reverse pulse", pins { 17,18 / 19, 20 }. This is not a step/direction drive. You will need something similar to a quad bilateral switch or similar logic to convert step/direction to work with this amplifier.
    See post here; http://www.cnczone.com/forums/servo_...rive_help.html .
    In other words, you need a high speed digital switch where you can switch a singe input to 2 outputs.
    In summary, the step pin output can be switched to the forward pulse and to the reverse pulse inputs by using the direction pin.
    Hope this helps,
    Iron-Man
    Mar 2009
    90
    Quote Originally Posted by Iron-Man View Post
    Hope this helps,
    Iron-Man
    I don't think that is the case with this driver, pleas see the picture. I highlight with read the forward pulse and reverse pulse signal's. It say's at "*1 Position command pulse input also possible using a pulse/direction system"
    I think it can be set to accept pulse/direction but the manual does not contain settings for this.
    Jan 2009
    334
    *1 Position command pulse input.
    Yes this is true, but it requires additional logic to make it work. You really need the manual for this amp. Getting the step/dir to work is just the beginning. You will have to set the PID in order for it to work correctly. You may also need software for it to work.
    As Al The Man stated, have you contacted Tamagawa support?
    Post pictures of what you have, somebody may just have a manual lying around.
    Hope this helps,
    Iron-Man
    Mar 2009
    90
    one step forward!!!
    Long time since i worked on my little project. But i managet to get some documentation regarding the parameters for tamagawa au6550 servo drivers. The first doc contains parameter imput method and second one contains a list of parameters for the driver's working under juki pick and place machine.
    Maybe someone can help me to find the right parameters for step and direction imput.
    Jul 2013
    3
    AU6550
    Dear,
    Could you share AU6550 manual to me ? I,d like you can help me get the alarm list.
    many tks
    Br
    [email protected]
    [email protected]
    Mar 2009
    90
    One step forward!
    I managed to start the motors from mach3. With a step/dir to cw/ccw convertor made from this schematic.Click image for larger version.
Name:	74241 step-dir to cw - ccw converter+ leds.jpg
    But now when i try to go forward (let's say A+, but just one step in mach) the motors start's and do not stop, if i "press again"A+" the motor rotates faster, and so on...; the same thing happens in the reverse direction "A-". The good thing is the motor is running very smoothly.
    Maybe i set something wrong in mach3 or the frequency is wrong.
    Apr 2013
    Hi, I'm working with just about the same combination of equipment. I have Yaskawa TBl-i 4507 servos on a3 axis MDF CNC. I've got two options. 1 find the drivers (au6550's?)and figure ohthow to program it all with Mach 3. Or 2. Buy different motor mounts 3 new steppers, controls ect.
    Did you ever get your setup to work properly?
    Mar 2009
    90
    I wired a driver (au6550) with all the original motor wires at a bob that knows pulse and direction and when i try to jog the motor, let's say X+ the motor start's running in cw direction. But it do not stops (it's running continuos in cw direction just by clicking once X+), if i click X- the motor change direction ccw and run continuos. I don't have any control on the motor
    Jan 2009
    334
    74LS241 proper termination of unsed I/O lines.
    Do you have access to an oscilloscope or logic probe? Check the outputs. In order for the 74LS241 to work correctly, any unused inputs and outputs must be properly terminated. Try this: Connect the unused I/O lines to 10 k resistors connected to ground. This way they will not “float” .
    Post pictures of your set-up.
    Hope this helps,
    Iron-Man
  1. Wiring two drivers to one circuit on Break Out
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 08-08-2012, 03:57 PM
  2. Wiring stepper motors to drivers
    By John DiBernardo in forum Stepper Motors / Drives
    Last Post: 06-06-2012, 01:23 AM
  3. Wiring Stepper Motors to drivers
    By xyzeugene in forum CNC Machine Related Electronics
    Last Post: 02-18-2010, 11:22 AM
  4. Boss 5 wiring new brain to stock drivers?
    By D.D.Machine in forum Bridgeport / Hardinge Mills
    Last Post: 05-22-2006, 04:58 PM
  5. Need help wiring drivers
    By InventIt in forum DIY CNC Router Table Machines
    Last Post: 03-09-2004, 03:57 AM
