585,949 active members*
3,999 visitors online*
Results 1 to 13 of 13
    May 2012
    G13 Circular Milling on FANUC
    Hello all,
    Attached is a scanned diagram from our HAAS milling machine manuals showing the G13 command, which is an incremental circular pocket milling command.
    This G13 command does not exist on our newer Fanuc 16i-M controller for our horizontal boring mill.
    Using the macro found here:
    Circle Milling A Bolt Hole Pattern : Modern Machine Shop
    I have been able to circular mill in a bolt hole pattern but in a single cut.
    There must be a way to take multiple cuts as in this G13 haas cycle?
    Any thoughts? Thank you in advance.
    May 2004
    4519
    Yeah. A custom macro.
    Are you wanting to know how to write one?
    May 2012
    Quote Originally Posted by txcncman View Post
    thank you, yes i am. i have a custom macro book here, that i have looked through and have used for minor changes in the past...but i am not very familiar at all with macros.
    does this macro already exist somewhere to be seen? i imagine this has been asked for many times, but still cant seem to find it.
    appreciate any insight.
    May 2004
    4519
    I am sure someone has a macro to do this already in their library. Maybe they will upload it here. Until then, if you have the Haas macro, you can modify/rewrite it to work with Fanuc.
    Feb 2007
    592
    Post
    There are 2 existing threads on this.
    In one I posted my G13 (yaznaq formatted) macro I use on a Mori Seiki with the MSC-518 ( Fanuc 18M) control.
    Others built on it and those results were in a later thread.
    May 2012
    Quote Originally Posted by skullworks View Post
    thanks, unfortunately 'G13' is not a searchable word on this forum...
    i've found one of the threads...
    http://www.cnczone.com/forums/fanuc/...g13_fanuc.html
    happen to have a link to the other? thank you
    Aug 2011
    2517
    hehe! I suspect that thread went over your head ;-)
    you can't use G13. it only cuts a single pass. you need a full blown pocket roughing macro.
    I have not seen anything useful like this on the net so I'll release one from my archives for the community :-)
    Here's a circle pocket milling macro I wrote about 25 years ago.
    This will mill a 50mm x 24.5mm deep circular pocket taking 5mm deep rough cuts with center X0 Y0.
    the explanation of the variables is at the bottom. just change the numbers on the G65 line to something simple in inches.
    for example....
    G65 P9205 A2. B0 E0.2 F0.01 H0 I2. J10. K2. Q40. R0.5 T-1. X0 Y0 Z-2.
    it should be relatively easy to understand what its doing but unless you're an expert dont try to understand the macro.
    just try it on the machine above the job/table to see the movements.
    O0001 (MACRO-CIRCLE POCKET MILLING)
    G40 G49 G90 G92 X-200. Y200. Z0
    G0 X0 Y0 G43 H1 Z100. S500 M3
    G65 P9205 A50. B0 E5. F1. H0 I50. J150. K50. Q40. R3. T-1. X0 Y0 Z-24.5
    G0 G49 Z0 M5
    G27 X-200. Y200. Z0
    M30
    O9205
    #7=#2064
    #10=#26+#9
    IF [[[#1/2]-[#2/2]] GT [#7*2]] GOTO 1
    #3000=64 (CUTTER LARGER THAN HOLE!)
    N1 IF [#20 GT 0] GOTO 2
    #12=3
    GOTO 5
    N2 #12=2
    N5 #13=#1/2
    #14=#2/2
    #15=#13-#9-#24-#7
    #16=#9+#7
    #19=2*#7*#17/100
    #21=#13-#14-2*#16
    #22=#21/#19
    #23=#21/#22
    #27=#13-#9-#7
    G0 X#24 Y#25
    Z#18
    X-#15
    #28=#11
    WHILE [#11 GT #10] DO 1
    #28=#28-#8
    IF [#28 GE #10] GOTO 3
    #28=#10
    N3 G1 Z#28 F#4
    G#12 I#27 F#5
    #29=1
    WHILE [#29 LE #23] DO 2
    G1 X-[#15-#29*#22] F#5
    G#12 I[#27-#29*#22]
    #29=#29+1
    END 2
    G0 Z#18
    X-#15 Y#25
    IF [#28 LE #10] GOTO 4
    G1 Z[#28+1] F[10*#4]
    END 1
    N4 #15=#13-#24-#7
    #21=#13-#14-2*#7
    #22=#21/#19
    #23=#21/#22
    #27=#13-#7
    G0 X-#15
    G1 Z#26 F#4
    G4 X.5
    G#12 I#27 F#6
    #29=1
    WHILE [#29 LE #23] DO 1
    G1 X-[#15-#29*#22] F#6
    G#12 I[#27-#29*#22]
    #29=#29+1
    END 1
    G0 Z#18
    M99
    #1 A:OUTSIDE DIAMETER
    #2 B:INSIDE DIAMETER
    #8 E:DEPTH OF ROUGHING CUT (Z AXIS)
    #9 F:FINISHING ALLOWANCE (COMMON TO ALL AXIS)
    #11 H:TOP OF JOB (Z AXIS)
    #4 I:FEEDRATE DOWN (Z AXIS)
    #5 J:FEEDRATE IN X-Y PLANE
    #6 K:FINISHING FEEDRATE
    #17 Q:PERCENTAGE OF CUTTER USED TO TAKE CUT IN X-Y PLANE
    #18 R:RAPID POINT ABOVE JOB
    #20 T:CUTTING DIRECTION 1=CLOCKWISE, -1=ANTI-CLOCKWISE
    #24,#25 X,Y:CENTRE COORDINATES OF CIRCLE
    #26 Z:DEPTH OF CAVITY
    #2064 TOOL DIAMETER OFFSET 64 (2001 - 2064)
    If using D1 use #2001
    May 2012
    fordav - thank you! i'm going to give this a try, looks like just what i need
    Jul 2010
    118
    the last step, you want to create your own G-code call in Fanuc 18m, G13 g-code,
    insert 13 in parameter 6050.
    renumber O9205 to O9010 and your done.
    now G13 will call program 9010, replace "G65 P9205" in your code,
    Apr 2007
    28
    G13 macro
    Here is a macro we use on all of our Fanuc controls. You need to position to center of feature, and move down to desired depth. This macro does "1" shot holes and also will spiral. You can also loop with L command. (G13 I.xxx Dx Fx Lx)
    Hope this helps.
    :9013(G13 SPIRALLING MACRO)
    #3003=1
    (FOR FANUC 15M AND 16M, 18M ONLY.)
    (15M PARAMETER 7053=13)
    (16M, 18M PARAMETER 6053=13)
    (G13,I,K,Q,D,F AND ALSO C)
    (ON SPIRAL I=START RAD, K=FINISH RAD)
    (Q=STEPOVER,D=DIAM OFFSET#,F=FEEDRATE)
    (EX. FOR 2 DIAM WITH START FOR 1/2)
    (G13I.25K1.0Q.1D1F25.0)
    (IF USED, I,K AND D MUST BE GIVEN IN)
    (THE SPECIFIC ORDER AS SHOWN ABOVE.)
    (OMIT K AND Q FOR REGULAR)
    (NON-SPIRALLING CIRCLE CUTTING.)
    (I=FINISH RAD)
    (EX. FOR 2 DIAM, G13 I1.0 D1 F25.0)
    (DECIMAL PT NOT NEEDED ON ARGUMENT D)
    (ALL OTHER ARGUMENTS MUST SHOW A DECIMAL PT)
    (C MAY ALSO BE USED FOR # OF FULL 360 DEGREE)
    (ROTATIONS BEFORE TOOL RETURNS TO CENTER.)
    (IF C IS NOT USED, #3 DEFAULTS TO 1.)
    (I=#4,K=#6,Q=#17,D=#7,F=#9,C=#3)
    #27=#5041
    #28=#5042
    #31=#4001
    #32=#4002
    #33=#4003
    IF[#3NE#0]GOTO1
    #3=1
    N1#3=ABS[FIX[#3]]
    #7=ABS[FIX[#7]]
    IF[#9NE#0]GOTO2
    #9=#4109
    N2#9=ABS[#9]
    IF[#4009EQ80]GOTO3
    #3000=150(NOT IN G80 STATUS)
    N3IF[#4007EQ40]GOTO4
    #3000=151(NOT IN G40 STATUS)
    N4IF[#4NE#0]GOTO5
    #3000=152(I VALUE NOT GIVEN)
    N5IF[#7NE#0]GOTO10
    #7=0
    N10#20=#[13000+#7]
    IF[[ABS[#20]]LT[ABS[#4]]]GOTO20
    #3000=153(TOOL RADIUS TOO LARGE)
    N20IF[#6NE#0]GOTO25
    #29=1
    #21=#4-#20
    #22=#21/2
    G17
    G91
    G3X#21Y0I#22J0F#9
    WHILE[#29LE#3]DO1
    X0Y0I-#21J0
    #29=#29+1
    END1
    X-#22Y#22I-#22J0
    X-#22Y-#22I0J-#22F#9
    GOTO40
    N25IF[#17NE#0]GOTO30
    #3000=154(Q VALUE NOT GIVEN)
    N30#17=ABS[#17]
    IF[[ABS[#6]]GT[ABS[#4]]]GOTO35
    #3000=155(I NOT LESS THAN K)
    N35IF[#4GT0]GOTO36
    #6=-[ABS[#6]]
    #17=-#17
    GOTO37
    N36#6=ABS[#6]
    N37#101=#5001
    #102=#5002
    #21=#4-#20
    #22=#21/2
    #16=#6-#20
    #15=#16/2
    #30=ABS[#16]-ABS[#21]
    G17
    G91
    G3X#21Y0I#22J0F#9
    X0Y0I-#21J0
    WHILE[#30GT[ABS[#17]]]DO2
    G1X#17F[#9/2]
    G3X0Y0I-[#21+#17]J0F#9
    #21=#21+#17
    #30=#30-ABS[#17]
    END2
    G90
    #29=1
    G1X[#101+#15]F#9
    Y[#102-#15]
    G3X[#101+#16]Y#102I0J#15F#9
    WHILE[#29LE#3]DO3
    X[#101+#16]Y#102I-#16J0
    #29=#29+1
    END3
    X[#101+#15]Y[#102+#15]I-#15J0
    X#101Y#102I0J-#15F#9
    N40G01G90X#27Y#28
    G#31G#32G#33
    F#9
    #3003=0
    M99
    Mar 2014
    30
    Re: G13 Circular Milling on FANUC
    Are this is for fanuc 15? The reason I ask is because I am new on the trade and since some time I need to do some spot face of 2.250 inch on diameter I will like to know how to use this macro.
    Thank you
    Best Regards
    Javier
    Dec 2015
    Sorry for the thread resurrection.
    I'm looking to build a macro for a y axis lathe that can helical mill to a depth in X (using the X, Y and Z axes) and then spiral mill out (using the Y and Z axes). I'm currently programming this longhand, which is fine, but it doesn't lend itself well to small changes. We also have manual guide on the machine but the fanuc cycles are not fit for purpose IMO
    Thanks in advance
    DB
    Jan 2008
    8
    Quote Originally Posted by db1974 View Post
    Thanks in advance
    DB
    Not a macro but this code generating Google Spreadsheet might work as well. I wrote it for a part with 2 diameters/depths. You just fill out the white cells on the lift hand side and it will create the code on the right hand side (? Copy the code below ?). It doesn't orientate the part in C (just add the C-value to the highlighted line in the code).
    I haven't tried it but I'm pretty sure it works.
    https://docs.google.com/spreadsheets...Hn6h4_9ousUFjI
  1. Spiral milling in a circular pocket
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-22-2011, 02:38 PM
  2. Deviation when milling a circular pocket.
    By zvika-g in forum Benchtop Machines
    Last Post: 04-22-2009, 01:36 AM
  3. Circular output in milling
    By blmmdes in forum UG NX
    Last Post: 09-03-2008, 01:19 PM
  4. Circular Milling - G12/G13
    By HPT in forum Servo Motors / Drives
    Last Post: 05-14-2006, 07:22 PM
