585,761 active members*
4,129 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Jan 2011
    Connect PC to Fagor 8055
    This does not seem to work. There seems to be a security lockout by the PC, which runs XP. I tried to eliminate the firewall and open file directories to network access.
    Has anyone successfully done this?
    TX JB
    Dec 2011
    73
    how are you trying to connect it to the pc? serial? ethernet?
    Jan 2011
    download from Fagor to PC running XP
    Quote Originally Posted by CNCTech25 View Post
    Pls excuse late reply. I am connecting with rs232 serial cable, and running Fagor sw - something like windnc or wincnc The cable is supposedly eied to Fagor specs.
    JB
    Apr 2004
    12
    connection
    we have a continus connection sillilar to an ethernet connection
    we use mulit dnc and use the remote connection
    Jan 2011
    ethernet?
    I don't think the 8055 has an ethernet connection.
    What is "mulit DNC?"
    Which OS are you using?
    Thanks in advance
    JB
    Apr 2004
    12
    I meant to say similar to ethernet
    it uses the rs232 communication port 9 pin
    multi-dnc is the software used to set protocalls
    the rest of the machines in the dept. also use the same software for uploading and downloading programs
    Apr 2004
    12
    sequence at the fagor is
    copy serial2 to program#111111
    the control will search the computer dirve for the program #111111
    when it finds it it loads it in control under 111111
    Jul 2003
    1220
    I download programs from PC to Fagor 8055MC via RS232 using Com1.
    I use Fagor's WINDNC on the PC.
    You need to set the Machine Parameters for Serial Port in the Controller and the Port Setting in the PC.
    If this is what you need, I can supply the setting I use.
    Jan 2011
    Quote Originally Posted by Kiwi View Post
    yes by all means, Thanks JB
    Jan 2011
    also please let me know the operating system you are using. I have XP.
    Jan 2011
    Quote Originally Posted by PatM View Post
    Thanks - will try.
    Dec 2011
    73
    Quote Originally Posted by jbrookes View Post
    Thanks in advance
    JB
    Fagor's 8055 controls do have ethernet, just not all of them. It depends on the vintage. Their modular systems originally used NetBUI through the hard drive module and then they eventually switched to TCP/IP on more recent versions (used to require an expansion board to the CPU, but now they come standard, you just have to buy the software option)
    Same thing with their compact units, but the hardware is not standard yet.
    Dec 2011
    73
    If you use Fagor's WinDNC, WinXP is good. I've run WinDNC on Win98, WinXP, Vista, Win7. No issues (that is if you dont consider not being able to uninstall on Win7 a issue...)
    I used to use DNC30 which is DOS based.
    WinDNC is your best bet to get a connection from control to PC etc. You can use the default serial parameters on the control since they're set for Fagor's protocol. All you would have to do is set up a profile in WinDNC for the connection and define the control model and match the baudrate to that of the control.
    could anyone post the right pi assignment for the the rs232 cable?
    Dec 2011
    73
    Quote Originally Posted by sting View Post
    Simplified connection is 2 to 3, 3 to 2, 5 to 5 and on each subD connection jump 4, 6, and 8 together. This will work for all 8055 controls (except for Eprom style, very old 8055 that came out right after the 8050)
    Mar 2005
    7
    Latest Windnc(from Fagor Spain) on XP. Serial port parameters on PC and CNC match. Upon start up of Windnc. screen titled 4456.txt has column on left with 3 .txt files and says local. Bottom of screen has black bar with C: in it. Red bar with what looks to be a network icon below the black bar. The only active things are the 3 file icons in the left column. Opening them just opens an empty page.
    Not 100% sure that the cable is correct. Only know that it works with Fanuc and very old 8020m control.
    Mar 2005
    7
    Quote Originally Posted by alphonso View Post
    Problem solved. Corrupted installation of Windnc. Reinstalled and everything works as it is supposed to.
    Mar 2014
    7
    help 8055tc with eprom I missing, cabel diagram, machine parameter
    Jul 2014
    20
    Re: Connect PC to Fagor 8055
    for 8055 with eprom or 8050 and older cnc fagor controls, the pin out is 2 to 2; 3 to 3; 5(pc)to 7(cnc); at cnc side join 5-6-9; at pc side join 8-6-4.
    set serial comunication parameters to their default value (hit initialize softkey) or try the comunication with windnc at 9600boudrate
    kind regards
    Jul 2014
    20
    hi
    for 8055 eprom series or 8055 and older cnc fagor controls, the cable pinout is 2 to 2; 3 to 3; 5(pc) to 7(cnc); join 4-6-8 at pc side; join 5-6-9 at cnc side;
    try thye comunication at 9600 baudrate all other parameter to default.
    kind regards
Page 1 of 2 12
  1. fagor 8055 tc
    By trarus in forum Fagor Automation
    Last Post: 01-19-2019, 06:17 PM
  2. Fagor 8055 G 54??
    By clayman in forum Uncategorised MetalWorking Machines
    Last Post: 08-19-2013, 06:29 PM
  3. fagor 8055
    By cncsed in forum Fagor Automation
    Last Post: 09-06-2011, 02:21 AM
  4. Fagor 8055 DNC communication
    By theartz in forum Fagor Automation
    Last Post: 01-12-2011, 11:13 PM
  5. HELP POSTING TO FAGOR 8055
    By rough_cut in forum Fagor Automation
    Last Post: 04-21-2010, 02:08 PM
