585,978 active members*
4,381 visitors online*
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Mar 2014
    7
    Re: Connect PC to Fagor 8055
    this not Work for me
    Simplified connection is 2 to 3, 3 to 2, 5 to 5 and on each subD connection jump 4, 6, and 8 together. This will work for all 8055 controls (except for Eprom style, very old 8055 that came out right after the 8050)
    this Works on my 8055 tc control whit Eprom --- I am happy now .. remeber hit initalize softkey
    for 8055 with eprom or 8050 and older cnc fagor controls, the pin out is 2 to 2; 3 to 3; 5(pc)to 7(cnc); at cnc side join 5-6-9; at pc side join 8-6-4.
    set serial comunication parameters to their default value (hit initialize softkey) or try the comunication with windnc at 9600boudrate
    for 8055 eprom series or 8055 and older cnc fagor controls, the cable pinout is 2 to 2; 3 to 3; 5(pc) to 7(cnc); join 4-6-8 at pc side; join 5-6-9 at cnc side;
    try thye comunication at 9600 baudrate all other parameter to default.
    kind regards
  2. #22
    Mar 2014
    7
    Quote Originally Posted by rui.orfao View Post
    hi
    kind regards
    i am happy now it´s Works whit windnc 9600 baud . :banana:
  3. #23
    Aug 2011
    Hi, Greatings from Portugal
    Need help with ethernet communication on windows 7
  4. #24
    Jun 2006
    143
    Instructions I got for setting our 8055 up
    TCP/IP HARD DISK & ETHERNET SETUP
    FAGOR 8055
    ( Direct to a PC using a crossover cable )
    ( The IP addresses used are for example purposes only, other IP addresses may be used )
    CNC PARAMETERS
    P1 = 0
    P2 = FAGORCNC (ANY NAME TO IDENTIFY THE HARD DISK)
    P22 = 1 (Sets communications to RS232/Serial 2 and Ethernet , disables RS422)
    P24 ( DIRIP ) = 10.1.1.2 ( IP Address of the CNC )
    P25 ( NetMask ) = 255.255.255.0 ( Must be set in PC as Subnet Mask )
    P26 ( IPGateway ) = 10.1.1.1 ( IP Address of the PC ) or ( IP Address of the Server )
    P27 ( IPSWDNC ) = 10.1.1.1 ( IP Address of the PC the CNC will use for DNC )
    WINDOWS XP SETTINNGS
    1. CLICK ON “Control Panel”
    2. CLICK ON “Network Connections”
    3. CLICK ON “Local Area Connection”
    4. CLICK ON “Internet Protocol(TCP/IP)”
    5. CLICK ON “Properties”
    6. CLICK ON “Use the following IP address”
    7. Enter in the IP Adress “ 10.1.1.1
    8. Enter the Subnet mask “ 255.255.255.0 “
    9. CLICK ON “OK”
    To Drag and Drop files from PC to CNC
    1. Open “WINDOWS EXPLORER”
    2. In the ADDRESS line type in FTP://10.1.1.2
    3. CLICK ON “Disk”
    4. CLICK ON “prg”
    ( This will bring up a list of the programs in the CNC )
    To create a shortcut on the DESKTOP of your PC
    1. CLICK ON the icon in the address bar of explorer that is right before the ftp://10.1.1.2 that
    you previously typed in , drag that to your desk top and drop it.
    WINDNC 4.0 (and higher) Connection
    In SETUP -
    1. Double Click the TYPE window and select “NETWORK NODE”
    2. Connect on Startup – double click the box to enter “X”
    3. Double Click the IP ADDRESS window and type in “10.1.1.2”
    ( This allows the WinDNC program to send and receive files just as if a serial cable were connected, just MUCH faster.)
Page 2 of 2 12
  1. fagor 8055 tc
    By trarus in forum Fagor Automation
    Last Post: 01-19-2019, 06:17 PM
  2. Fagor 8055 G 54??
    By clayman in forum Uncategorised MetalWorking Machines
    Last Post: 08-19-2013, 06:29 PM
  3. fagor 8055
    By cncsed in forum Fagor Automation
    Last Post: 09-06-2011, 02:21 AM
  4. Fagor 8055 DNC communication
    By theartz in forum Fagor Automation
    Last Post: 01-12-2011, 11:13 PM
  5. HELP POSTING TO FAGOR 8055
    By rough_cut in forum Fagor Automation
    Last Post: 04-21-2010, 02:08 PM
