I have a part made from Polyethylene that is 1/2" in diameter, 1/8 thick, and with a 1/8 hole thru the center. I am having a problem with the part expanding in diameter out of my +/-.0015 tolerance after they leave my department. The parts are being made in a Citizen L20 from ground material with all uncoated carbide tools. I think the problem is being caused during the cleaning process, may be the water is too hot or too cold, maybe they are being left near a hot or cold window(winter here so it's cold window) or may be even the cleaner being used (LPS Precision clean) could be the problem. I should also point out I ran a test were I left the parts in my department over night then had our qc person check the diameter in question and they were fine. Any help will be great. Thanks Brian
