Hi everybody,
I just received my new chinese machine K45MT-S cnc routers with 2 spindles, one vertical and one horizontal. of course not any installation manual and user guide at all. installed and setup by myself and using forums in this sites. but there is some problem.
I can load g-code programs and doing every things I want as well, but before loading I have to choose and move down spindle via DSP manually and also turn it on and then run program.
received instruction about M command for choosing spindles and turning on or off but this commands inside the G-code program absolutely doing nothing and this is the problem. I'm pushing DSP menu key 3 times and changing arrowhead of no 2,3,6, or 7 for using and turning on spindles.
could anybody help me to handle situation by g-code program?
maybe it's need to do some change inside the DSP? my DSP is 0501 but back side indicated as RZNC-0505HEBC.
pls help.
