585,902 active members*
3,921 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Can I do a absoute linear move on one axis, and a relative a-axis move same time?
Results 1 to 8 of 8
    673
    Just checking - I make a part with rotary indexing and it would go faster to do an absolute y axis move at the same time (asyncronously) as the A axis is doing its thing in relative mode... I don't want to sync axis, just rapid them both at their own max speeds at the same time... is that possible?
    24221
    G00 for both on the same line?
    Al.
    Albert E.
    Feb 2006
    1792
    No idea about A-axis, but G00 X_ W_ and and G00 U_ Z_ are permitted on a lathe.
    Aug 2011
    2517
    If you do G00 Y... A... they are both absolute.
    If there is a letter for relative A axis then you can use it if it's a lathe.
    On a lathe with C axis, relative is H.
    But there is no A axis on a lathe so there is no relative A axis letter.
    If you switch your A Axis to make it C then H may work if it's a lathe.
    If it's a mill it probably won't work because on a mill you can only switch
    absolute/incremental mode using G90/G91 and the CNC-controlled axes are
    restricted to X Y Z A B C (and in special cases additional axes U V W)
    A mill does not understand any axis movement as relative unless you specify
    G91 first and in that case you specify only X Y Z A B C
    So the short answer is 'no'
    May 2004
    4519
    Quote Originally Posted by Spinnetti View Post
    Post your code as it is now. I was to see what you are currently doing.
    Jul 2010
    118
    G00 > rapid, individual or combined move ?
    for fanuc 21iA/31iB see parameter 1401#1, LRP, where this decision is made.
    only if your lathe is set for G-code group A would X(in abs) W(incrimental) combination work in the same line.
    G-code group B & C works the same as a milling control where only one ,G90 or G91, is valid for the whole line.
    if you need prm.1401#1 setting to be different in some parts of your program ,to your own preference, G10 can be used when needed.
    Aug 2011
    2517
    He doesn't say, but it appears he has a mill so W does not apply and he has
    to use G90/G91 and then all movement on one line is either one or the other.
    Just program it all in absolute and move on.
    673
    Thanks for the replies.. Answer is no, it doesn't work... not on my machine anyway.
    I wanted to do true coordinated moves but can't because by default the tormach rotary table doesn't know where it is. I can work around, but was just trying to reduce cycle times by doing my a and x/y/z moves all at once.
  1. Y axis cannot move up...
    By rararuru in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-30-2009, 02:21 AM
  2. All axis will not move
    By SELECT in forum Fadal
    Last Post: 09-30-2009, 04:37 PM
  3. how to move the Z axis
    By cob in forum Mach Mill
    Last Post: 08-23-2008, 01:56 AM
  4. G91 B axis move?
    By DocHod in forum G-Code Programing
    Last Post: 11-02-2007, 05:56 AM
  5. How do you move an axis manually ?
    By Eurisko in forum DIY CNC Router Table Machines
    Last Post: 04-07-2007, 03:00 AM
