What controller is on the lathe?
I don't have personal knowledge of this slide but it sounds to me like the pump is going to run until a L.S is made so what happens if you trip the limit by manually?
If a move is commanded, I assume it runs the pump which would also pick up a solenoid for the extend or retract?
If so is either solenoid picking up? If neither the pump will run continuously.
IF a solenoid is picking up, and the slide is not moving, then it points to a mechanical seize of some kind?
Do you have schematics of any kind?
Not sure if this helps, but it is hard to troubleshoot from a distance.
Al.
Albert E.
