585,717 active members*
4,087 visitors online*
IndustryArena Forum > CAM Software > Vectric > Cut2D / Cut3D > Cut2D new user question.
    Jan 2008
    Hi Guys,
    I'm a recent newbie to Cut2d and love the program so far. I have a question with regard to my first project with it.
    I'll be cutting approx 15 different outside profiles in a small sheet of 1/4" birch ply. I used the tabs on toolpath feature on all the profiles. Now I want to change the size of the tabs. Is there a way to do this globally or do I need to edit each individual toolpath and regenerate?
    Thanks, ub52
    I don't believe there are any toolpath setting that can be modifies globally.
    So yes, you'll need to do it individually.
    Aug 2008
    12
    In Cut 2D how I can manage (change) the vertical tool gap for free translation from one chain or toolpath to the next ?. At this moment the program is setted at 1 mm gap, but I need more than that, at least 5 mm to asure that the tool will not hit the working piece, specially when I am milling a pocket. Many thanks for any help.
    Aug 2008
    12
    In Cut 2D I am not able to importing DXF from AutoCAD at all, there is a message as "failed to open drawing". Any reason who somebody knows ?.
    Quote Originally Posted by mvd535 View Post
    Save as v12 .dxf from AutoCAD.
  1. Cut2d question
    By fast_project in forum Vectric
    Last Post: 10-04-2011, 09:45 PM
  2. very new user question
    By LockTech in forum BobCad-Cam
    Last Post: 10-16-2009, 07:28 PM
  3. Gibbs user question
    By sunfire03 in forum GibbsCAM
    Last Post: 04-09-2008, 10:08 PM
  4. New user Master 5 question.
    By wjbzone in forum Mach Software (ArtSoft software)
    Last Post: 06-06-2003, 12:08 PM
